Arduino Leonardo and linears encoders.
25 Jan 2013 19:08 #29128 by casetero
Replied by casetero on topic Arduino Leonardo and linears encoders.
Ok, hidcomp creates 4 diferent PINs, and for each PIN 3 diferent type of, and one of them is float. I put you the s32 one because i thought it was the easyer to manage.
So with the command you have posted every time i push a button, it keep the float value in all comps?
Example: I push button 1, that button shows a value of -0.997. So that value will be kept in all comps (comp.0.in, comp.1.in,....) or i have to expecificate the comp i want to keep the value?
The pendant i´ve bought is this one:
If you know any hal file done to this kind of pendant it would be great, because i want to use the LCD too.
Thank you very much.
25 Jan 2013 20:22 #29129 by andypugh
Replied by andypugh on topic Arduino Leonardo and linears encoders.
Normally it would be, but the "comp" HAL component works with float values.
[/quote]So with the command you have posted every time i push a button, it keep the float value in all comps?[/quote]Sorry, I am not sure what you mean by "keep" in that sentence.
Can you make a table of values for all pins and all buttons? Perhaps I can figure out the logic.
I had a look a the website, and it is a bit too expensive for me to buy one to experiment with.
Interestingly the "support" section of the salecnc website offers a support file called "Shuttlepro.rar" which might indicate that the internals are from
www.thomann.de/gb/contour_av_solutions_s...W_g7UCFYlb3god1y8AqQ
In which case we have:
linuxcnc.org/docs/html/man/man1/shuttlexpress.1.html
What name does our MPG give itself in HID?
The following user(s) said Thank You: casetero
25 Jan 2013 20:43 #29131 by casetero
Ok, i´m going to make the list with the buttons and the values they show.
I don´t know where to look the HID, but i can tell you that if i put "lsusb" in a terminal it is called Silicon Lab, and if i put "hidconfig" when selecting the device it shows KTURT in the name.
So maybe with shuttlexpress i can manage all? That would be great.
Thank you!
25 Jan 2013 20:51 #29132 by casetero
EUREKA!!! (I suposse is not a spanish word)
In the drivers of the pendant is the file ShuttlePro.dll so it does work with that driver for sure.
With it i can manage the LCD too??
Thank you!
25 Jan 2013 20:58 #29134 by andypugh
With it i can manage the LCD too??!
I am not sure.
Can you list the HAL pins?
25 Jan 2013 21:50 #29135 by casetero
Ok folowing this picture:
fr.aliexpress.com/item/CNC-wireless-MPG-...pping/642118415.html
I have numbered the buttons like this:
1
2 3 4 5
6 7 8 9
10 11 12 13
14 15 16
I charge the hid file with hidcomp at hal file like this:
loadusr -W hidcomp -ini smartsept.ini mando.hid
In the HAL meter, i see these PIN´s:
hidcomp.0.PIN1.raw
hidcomp.0.PIN1.ivalue
hidcomp.0.PIN1.fvalue
hidcomp.0.PIN2.raw
hidcomp.0.PIN2.ivalue
hidcomp.0.PIN2.fvalue
hidcomp.0.PIN3.raw
hidcomp.0.PIN3.ivalue
hidcomp.0.PIN3.fvalue
hidcomp.0.PIN4.raw
hidcomp.0.PIN4.ivalue
hidcomp.0.PIN4.fvalue
hidcomp.0.PIN5.raw
hidcomp.0.PIN5.ivalue
hidcomp.0.PIN5.fvalue
The Pins that have PIN1 and PIN5 shows the same value ( it is a repeated PIN i think)
PIN1 and PIN5 are referred to the main buttons (1-16),
PIN2 is for pressing two buttons at the same time ( in fact you mantain pressed one button and press another and give you different values depending on the two buttons you press, i think is for example to jog in velocity mode by pressing the velocitiy and the axis)
PIN3 is for the axis selector ( 6 positions, 4 axis and feed and spindle velocity)
PIN4 is for the pulse train to make and incremental jog. This one is rare, if you move slow the rotary button it shows 1, 1, 1, but if you move it faster it shows 2, 3 .. more faster, higher number.
I´ve made a list of values for PIN1 and PIN5 for the main buttons:
hidcomp.0.PIN1(or 5).fvalue :
Buttons Values of hal meter
1 -0.8198
2 -0.9922
3 -0.9844
4 -0.9766
5 -0.9688
6 -0.906
7 -0.953
8 -0.9452
9 -0.9374
10 -0.9296
11 -0.9216
12 -0.9138
13 -0.9608
14 -0.8982
15 -0.8902
16 -0.8824
hidcomp.0.PIN1(or 5).raw:
Button Value
1 23
2 1
3 2
4 3
5 4
6 12
7 6
8 7
9 8
10 9
11 10
12 11
13 5
14 13
15 14
16 15
25 Jan 2013 21:52 #29136 by casetero
Sorry it is a bit anoying to see but this wordprocessor haven´t respect me the spaces.
Do you understand it?
Thank you
29 Jan 2013 02:06 - 29 Jan 2013 02:06 #29230 by casetero
Hello Andy,
I´ve been doing some code to the incremental jog with the weel. It works with the comp function, but there is a problem.
This is the code i have wrote:
loadrt comp count=1
addf comp.0 servo-thread
setp halui.jog-speed 100
setp halui.jog.0.increment 0.1
setp comp.0.in0 -0.9988
net comparator hidcomp.0.PIN4.fvalue comp.0.in1
net x-jog comp.0.out halui.jog.0.increment-plus
Ok, it just moves in one direction. The first value that shows when moving the wheel is -0.9922 and in rest is -1.
The problem is that the hidcomp.0.PIN4.fvalue doesn´t return to -1 (rest) if i move the wheel fast, in fact i have to move it very slow to let it return to -1, so the comp can´t send a FALSE value between TRUE values, it stays in TRUE till i stop moving the wheel. So if i move the wheel with a normal velocity comp.0.out stays in TRUE value and it just move one increment while moving the wheel.
If i could manage to make a much more faster reading of the PIN it should work nicely i think. Can i do this by adding another thread much more faster? Maybe with the shuttleexpress i can do that too. But as i see at the url you posted, for the wheel it gives a float value, so i have to do a comp function too??
Last edit: 29 Jan 2013 02:06 by casetero. Reason: errates
29 Jan 2013 05:06 #29238 by andypugh
Hello Andy,
I´ve been doing some code to the incremental jog with the weel. It works with the comp function, but there is a problem..
I would be surprised if "comp" was the right way to interface the incremental jog.
Furthermore, if it is a Shuttle then the jog behaviour is just plain wierd.
The best solution is probably going to be a custom HAL component that handles all the complexity for you.
Whether that is an attractive solution depends on how comfortable you are with C-code.
Looking at www.linuxcnc.org/docs/html/hal/comp.html will either have you running away in fear or excited by the possibilities :-)
29 Jan 2013 20:29 #29258 by casetero
Ok, im going to try the shuttlexpress before making my own HAL component. It´s an amazing idea but i don´t know if i will be able.
Shuttlexpress has a PIN called shuttlexpress.0.counts that acumulate counts of the jog wheel, but it isn´t bit type, is s32. Do i have to connect it to stepgen.0.counts??
Im having problems to give permissions to shuttlexpress, I dont really undestand what happens when i put lsusb in a terminal. The devices that show me are real usb devices, or software modules like shuttlexpress must be showed too??
I have done a .rules files wich includes these lines:
# Generic HID device
SYSFS{idProduct}=="04d9", SYSFS{idVendor}=="1c40", MODE="0660", GROUP="plugdev"
# Contour design, shuttle pro
SYSFS{idProduct}=="0030", SYSFS{idVendor}=="0b33", MODE="0660", GROUP="plugdev",
# Mando chino
SYSFS{idProduct}=="eb70", SYSFS{idVendor}=="10ce", MODE="0660", GROUP="plugdev"
#El 002/002
SYSFS{idProduct}=="0200", SYSFS{idVendor}=="04f2", MODE="0660", GROUP="plugdev"
#Input
SUBSYSTEM=="input", mode=="0660", group=="plugdev"
#Otra para Shuttlexpress
SUBSYSTEM=="hidraw", ATTRS{idVendor}=="0b33", ATTRS{idProduct}=="0020", MODE=="0440"
And when i put in a terminal lsusb the Shuttle contour doesn´t appear. When i put:
halrun
loadusr shuttlexpress /dev/bus/usb/005/002 ( the device of the usb pendant)
it says that hidraw doesn´t have permissions.
What am i doing wrong??
Time to create page: 0.164 seconds
