Arduino Leonardo and linears encoders.
- Thank you received: 5013
01 Feb 2013 21:04 #29440
In that case, I think that the right thing to do is write a driver based on shuttlexpress.c
Most of the setup code can stay the same, except for the ID numbers. I think you already have that part working.
The next thing to do is to see what data you are getting. If you look at lines 132 to 141 in shuttlexpress.c you can see that it is looking at an array of "packets"
The first thing I would do would be to create some new HAL pins, of type U32, one for each "packet" and see what data is being received.
The HAL pins are created and defined in lines 222 to 273. 258 creates an S32 type, but U32 might be clearer.
You can then work on creating a HAL pin for every button, and for the jogwheel, etc.
With luck you might also find out how to interface the LCD. Is there any sign of an _input_ pin being created in HAL by hidcomp?
Replied by andypugh on topic Arduino Leonardo and linears encoders.
This pendant is part of my final carreer project, and i have to try to link correctly with linuxcnc,
The following user(s) said Thank You: casetero
- casetero
02 Feb 2013 00:44 - 02 Feb 2013 00:52 #29449
by casetero
Replied by casetero on topic Arduino Leonardo and linears encoders.
Now i´m not with the machine, but seeing the code of shuttlexpress.c, the position of the arrays is when it put
packet[3] & 0x10 for example??
So i have to put one line for each position of the array, suposing that it has "0" colums and "80" rows??
Reallty the normal buttons of the pendant i think i can manage them with the comp function and hidcomp. But maybe is better to link all to the modificated shuttlexpress.
The counts of the jogwheel are readed in lines 154-159, are they? Wich value have i to modify in these lines to try another source signal to read? this one *s->hal->spring_wheel_s32 = packet[0]??
The PINs that hidcomps creates are just these:
hidcomp.0.PIN1.raw
hidcomp.0.PIN1.ivalue
hidcomp.0.PIN1.fvalue
hidcomp.0.PIN2.raw
hidcomp.0.PIN2.ivalue
hidcomp.0.PIN2.fvalue
hidcomp.0.PIN3.raw
hidcomp.0.PIN3.ivalue
hidcomp.0.PIN3.fvalue
hidcomp.0.PIN4.raw
hidcomp.0.PIN4.ivalue
hidcomp.0.PIN4.fvalue
hidcomp.0.PIN5.raw
hidcomp.0.PIN5.ivalue
hidcomp.0.PIN5.fvalue
And all them are linked to buttons, so hidcomps doesn´t create PINs for the LCD i think. But maybe i have to do something in hidcomp for working with LCD, i haven´t investigate it yet.
Another thing i saw is that when i start hidcomp in the custom.hal (hal ini file) with my pendant linked, and in the next line i do the same with shuttlexpress, the last one doesn´t work. And vice versa. So in some kind of way when one of them link the device, this one keep with it and doesn´t get shared ( maybe they are jealous).
Thank you Andy.
hidcomp.0.PIN1.raw
hidcomp.0.PIN2.raw
hidcomp.0.PIN3.raw
hidcomp.0.PIN4.raw
hidcomp.0.PIN5.raw
Thank you Andy.
Last edit: 02 Feb 2013 00:52 by casetero.
02 Feb 2013 17:29 #29474
No, it's not that complicated.
I am thinking in terms of just
87 hal_u32_t debug1
88 hal_u32_t debug2
89 hal_u32_t debug3
90 hal_u32_t debug4
143 s->hal->debug1 = packet[0]
144 s->hal->debug2 = packet[1]
145 s->hal->debug3 = packet[2]
146 s->hal->debug4 = packet[3]
261 r = hal_pin_u32_newf(HAL_OUT, &(s->hal->debug1), hal_comp_id, "%s.%d.debug1", modname, num_devices);
262 if (r != 0) goto fail1;
(and so on)
87 hal_u32_t debug1
88 hal_u32_t debug2
89 hal_u32_t debug3
90 hal_u32_t debug4
(and so on)
- casetero
02 Feb 2013 21:14 #29486
by casetero
Ok, i think i have understood you.
Continue on monday...
Thank you!!
Thank you!!
Time to create page: 0.065 seconds
