Arduino Leonardo and linears encoders.
- casetero
axis.N.jog-counts pin
shuttlexpress.0.counts
May work as a train of pulses.
ArcEye, before just have one file.rules with all the devices, i have change it and put the etc/udev/rules.d/99-shuttlexpress.rules file with just one entry like the letter says. Nothing change, it continues without permissions, i copy to you what it says:
halcmd: loadusr shuttlexpress
halcmd: shuttlexpress: checking /dev/hidraw0
shuttlexpress: dev /dev/hidraw0 has unexpected Vendor ID 0x04f2 (expected Contour Design, 0x0b33)
shuttlexpress: checking /dev/hidraw1
shuttlexpress: dev /dev/hidraw1 has unexpected Vendor ID 0x04f2 (expected Contour Design, 0x0b33)
shuttlexpress: checking /dev/hidraw2
shuttlexpress: dev /dev/hidraw2 has unexpected Vendor ID 0x04f2 (expected Contour Design, 0x0b33)
shuttlexpress: checking /dev/hidraw3
shuttlexpress: dev /dev/hidraw3 has unexpected Vendor ID 0x10ce (expected Contour Design, 0x0b33)
shuttlexpress: no devices found
and when i type lsusb it says:
pablo@Pablo-cnc:~$ lsusb
Bus 005 Device 002: ID 10ce:eb70 Silicon Labs
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 04f2:0200 Chicony Electronics Co., Ltd
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 0dda:2026 Integrated Circuit Solution, Inc. USB2.0 Card Reader
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Maybe is not a permissions problem and i´m doing anythingelse bad, i don´t know.
Thank you!
- BigJohnT
- Thank you received: 1177
- ArcEye
- Thank you received: 758
This is your Chicony USB keyboardhalcmd: shuttlexpress: checking /dev/hidraw0
This is the Silicon Labs deviceshuttlexpress: checking /dev/hidraw3
I have done a .rules files wich includes these lines:
# Generic HID device
SYSFS{idProduct}=="04d9", SYSFS{idVendor}=="1c40", MODE="0660", GROUP="plugdev"
# Contour design, shuttle pro
SYSFS{idProduct}=="0030", SYSFS{idVendor}=="0b33", MODE="0660", GROUP="plugdev",
# Mando chino
SYSFS{idProduct}=="eb70", SYSFS{idVendor}=="10ce", MODE="0660", GROUP="plugdev"
#El 002/002
SYSFS{idProduct}=="0200", SYSFS{idVendor}=="04f2", MODE="0660", GROUP="plugdev"
#Input
SUBSYSTEM=="input", mode=="0660", group=="plugdev"
I think you need to get rid of all these rules. There should be no need for rules for generic keyboards, mice and USB to UART bridge controllers (or whatever the Silicon Labs device is, I can't find the device code easily)
I have only 3 rules in /etc/udev/rules.d (70-persistent-CD.rules 70-persistant-net.rules and 99-rtai.rules)
Somehow they are claiming hidraw.
Unfortunately I cannot test anything because I don't have your device
- casetero
The Silicon Labs device is the USB pendant, i don´t know if i understand you fully, but it should be the idVendor = 0b33 instead 10ce like it is??
I gave permissions to the Silicon Labs device because if not hidconfig wasn´t able to open the device. Maybe i should try to open it without hidcomp, just with
loadusr -W hal_input -KRAL Dual ??
So i have to desactivate all the rules?
So you don´t have the entry to give the permisions to shuttlexpress?
Thank you.
- casetero
And it should be 0b33 to be compatible??
The pendant came with a cd that had a ShuttlePro.dll in it, because of that i thought it was compatible, and the wheel has a similar signal to the signals described on the shuttlexpress page, the spring-wheel, maybe i´m wrong...
Thank you!
- ArcEye
All I can do is point out that hidraw0 appears to be linked to your keyboard, which should not require a rule at all
and your USB pendant also appears to be conflicting.
You are in rather uncharted seas, because you have a Windoze USB pendant which you are trying to interface with a component that is meant for use with a different piece of hardware you don't have
Do you think the problem could be that the pendant is not suitable for shuttlexpress since it has an idVendor = 10ce
Yes I suspect that is precisely the problem
If you look at shuttlexpress.c the vendor and device codes are hard coded into the component
that is where the error messages you are getting come from
- ArcEye
The code for shuttlexpress.c will give you one off the shelf that you can change the defines to match your pendant IDs.
Then you can set up the udev rules for the vendor and device IDs of your pendant and see if it will all load.
After that it is just the small matter of whether component, as written, will do what you want, but at least you will have a base to start from.
- casetero
Shuttlexpress just works with idVendor´s 0b33 and the idVendor of my pendant is 10ce.
Is it possible, isnt it??
Ok, i´m going to try to modificate the component shuttlexpress to making it able to read devices with this idVendor.
Thank you again.
- ArcEye
I have just changed the IDs in shuttlexpress.c to those of my Saitek games controller and recompiled
The component loads and recognises the controller, even without any udev rules (I am running as root)
So you should be able to progress from there
shuttlexpress: dev /dev/hidraw0 has unexpected Vendor ID 0x093a (expected Saitek, 0x06a3)
shuttlexpress: dev /dev/hidraw1 has unexpected Vendor ID 0x04b4 (expected Saitek, 0x06a3)
shuttlexpress: dev /dev/hidraw2 has unexpected Vendor ID 0x04b4 (expected Saitek, 0x06a3)
shuttlexpress: found Saitek P990 Dual Analog Pad on /dev/hidraw3
show all
Loaded HAL Components:
ID Type Name PID State
5 User shuttlexpress 12349 ready
3 User halcmd12347 12347 ready
Component Pins:
Owner Type Dir Value Name
5 bit OUT FALSE shuttlexpress.0.button-0
5 bit OUT TRUE shuttlexpress.0.button-0-not
5 bit OUT TRUE shuttlexpress.0.button-1
5 bit OUT FALSE shuttlexpress.0.button-1-not
5 bit OUT TRUE shuttlexpress.0.button-2
5 bit OUT FALSE shuttlexpress.0.button-2-not
5 bit OUT TRUE shuttlexpress.0.button-3
5 bit OUT FALSE shuttlexpress.0.button-3-not
5 bit OUT TRUE shuttlexpress.0.button-4
5 bit OUT FALSE shuttlexpress.0.button-4-not
5 s32 OUT 0 shuttlexpress.0.counts
5 float OUT -0.1428571 shuttlexpress.0.spring-wheel-f
5 s32 OUT -1 shuttlexpress.0.spring-wheel-s32
Sorry I didn't grasp early enough what it was that you were actually doing, I was addressing the symptoms not the underlying problem
- casetero
Or i have to download it? I have found one here but i don´t know if it will fit with the 2.5 version:
www.gitorious.org/emc-rt-preempt/emc-rt-...omps/shuttlexpress.c
Thank you, i´m going now!
