Joystick
01 Mar 2013 03:31 #30695 by no-bug
Joystick was created by no-bug
Hello
I'm trying to install a Logitec Dual Action joystick whith EMC2 2.5.1 on ubuntu Hardy Heron using this link wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant..
Step 4, EMC crashes when starting.
The joystick has been calibrated whith no problem (jscalibrator).
i've tried other solutions (discribed in wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNCKnowledgeBase) whith never endind problems of missing packages, wrong version of installed packages and install errors.
Is there a solution?
01 Mar 2013 07:30 - 01 Mar 2013 07:31 #30701 by BigJohnT
Replied by BigJohnT on topic Joystick
Attach the output from dmesg as shown here .
I don't have a clue what your doing to get missing packages and all that other stuff...
Last edit: 01 Mar 2013 07:31 by BigJohnT.
01 Mar 2013 18:50 - 01 Mar 2013 19:14 #30711 by no-bug
Replied by no-bug on topic Joystick
Hello John
Here are the attachments. I also add the error message when EMC crashes at start. If a copy of my machine.ini and hal files or custom_postgui.hal could be helpfull, I can send them.
ps : EMC crashes when hal is modified as discribed in the help link.
Last edit: 01 Mar 2013 19:14 by no-bug.
01 Mar 2013 18:57 - 01 Mar 2013 19:00 #30712 by no-bug
the second file
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.4
LINUXCNC - 2.5.1
Machine configuration directory is '/home/jp/linuxcnc/configs/ma-machine'
Machine configuration file is 'ma-machine.ini'
INIFILE=/home/jp/linuxcnc/configs/ma-machine/ma-machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
Shared memory conflict or RT component not loaded!
ERROR CLASSICLADDER- Ladder memory allocation error
Running HAL shutdown script
Killing task linuxcncsvr, PID=5894
Killing task milltask, PID=6031
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
custom_postgui.hal:18: Pin 'input.0.btn-trigger' does not exist
5894
PID TTY STAT TIME COMMAND
6031
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 1188.706297] I-pipe: Domain RTAI registered.
[ 1188.706326] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 1188.706330] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 1188.706339] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1188.706343] PIPELINE layers:
[ 1188.706346] d0dc9000 9ac15d93 RTAI 200
[ 1188.706350] c0383180 0 Linux 100
[ 1188.788842] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1188.790000] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 1188.790016] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 1188.790022] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 1395800000 hz.
[ 1188.790026] RTAI[sched]: timer setup = 2010 ns, resched latency = 2689 ns.
[ 1188.923997] RTAI[math]: loaded.
[ 1189.909627] config string '0x378 out '
[ 1200.171521] RTAI[math]: unloaded.
[ 1200.246793] SCHED releases registered named ALIEN RTGLBH
[ 1200.263644] RTAI[malloc]: unloaded.
[ 1200.362759] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1200.367613] I-pipe: Domain RTAI unregistered.
[ 1200.367632] RTAI[hal]: unmounted.
Last edit: 01 Mar 2013 19:00 by no-bug.
01 Mar 2013 19:14 #30713 by ArcEye
Replied by ArcEye on topic Joystick
See this thread
www.linuxcnc.org/index.php/english/forum...g-215-from-243#28091
The name of the button changed at version 2.5 or 2.5.1
01 Mar 2013 22:55 #30717 by BigJohnT
I updated the wiki site to show the correct name for the current version.
The following user(s) said Thank You: ArcEye
01 Mar 2013 23:24 - 01 Mar 2013 23:34 #30718 by no-bug
hello ArcEye
I've tried to rename trigger in joystick, but emc crashes. In attachement, hal file, EMC error message and halcmd show pin. I've very poor knowledges whith Linux and I do my best to understand !
I can't attache doc, so I do a copy
EMC error msg
insmod: error inserting '/usr/realtime-2.6.24-16-rtai/modules/rtai_hal.ko': -1 File exists
5007
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
custom_postgui.hal
loadrt or2 count=2
loadrt mux4 count=1
addf or2.0 servo-thread
addf or2.1 servo-thread
addf mux4.0 servo-thread
# set the jog speed for the joypad again use numbers that make sense for your machine
setp mux4.0.in0 0 # this one must be 0 to prevent motion unless a button is pressed
setp mux4.0.in1 25
setp mux4.0.in2 100
setp mux4.0.in3 200
# the following does the magic of setting the jog speeds
net remote-speed-slow or2.0.in0 input.0.btn-joystick
net remote-speed-medium or2.1.in0 input.0.btn-thumb
net remote-speed-fast or2.0.in1 or2.1.in1 input.0.btn-thumb2
net joy-speed-1 mux4.0.sel0 <= or2.0.out
net joy-speed-2 mux4.0.sel1 <= or2.1.out
net joy-speed-final halui.jog-speed <= mux4.0.out
net joy-x-jog halui.jog.0.analog <= input.0.abs-x-position
net joy-y-jog halui.jog.1.analog <= input.0.abs-y-position
net joy-z-jog halui.jog.2.analog <= input.0.abs-rz-position
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
5 s32 OUT 0 input.0.abs-hat0x-counts
5 s32 IN 0 input.0.abs-hat0x-flat
5 s32 IN 0 input.0.abs-hat0x-fuzz
5 bit OUT FALSE input.0.abs-hat0x-is-neg
5 bit OUT FALSE input.0.abs-hat0x-is-pos
5 float IN 0 input.0.abs-hat0x-offset
5 float OUT 0 input.0.abs-hat0x-position
5 float IN 1 input.0.abs-hat0x-scale
5 s32 OUT 0 input.0.abs-hat0y-counts
5 s32 IN 0 input.0.abs-hat0y-flat
5 s32 IN 0 input.0.abs-hat0y-fuzz
5 bit OUT FALSE input.0.abs-hat0y-is-neg
5 bit OUT FALSE input.0.abs-hat0y-is-pos
5 float IN 0 input.0.abs-hat0y-offset
5 float OUT 0 input.0.abs-hat0y-position
5 float IN 1 input.0.abs-hat0y-scale
5 s32 OUT 127 input.0.abs-rz-counts
5 s32 IN 15 input.0.abs-rz-flat
5 s32 IN 0 input.0.abs-rz-fuzz
5 bit OUT FALSE input.0.abs-rz-is-neg
5 bit OUT FALSE input.0.abs-rz-is-pos
5 float IN 127.5 input.0.abs-rz-offset
5 float OUT -0.003921569 input.0.abs-rz-position
5 float IN 127.5 input.0.abs-rz-scale
5 s32 OUT 127 input.0.abs-x-counts
5 s32 IN 15 input.0.abs-x-flat
5 s32 IN 0 input.0.abs-x-fuzz
5 bit OUT FALSE input.0.abs-x-is-neg
5 bit OUT FALSE input.0.abs-x-is-pos
5 float IN 127.5 input.0.abs-x-offset
5 float OUT -0.003921569 input.0.abs-x-position
5 float IN 127.5 input.0.abs-x-scale
5 s32 OUT 127 input.0.abs-y-counts
5 s32 IN 15 input.0.abs-y-flat
5 s32 IN 0 input.0.abs-y-fuzz
5 bit OUT FALSE input.0.abs-y-is-neg
5 bit OUT FALSE input.0.abs-y-is-pos
5 float IN 127.5 input.0.abs-y-offset
5 float OUT -0.003921569 input.0.abs-y-position
5 float IN 127.5 input.0.abs-y-scale
5 s32 OUT 127 input.0.abs-z-counts
5 s32 IN 15 input.0.abs-z-flat
5 s32 IN 0 input.0.abs-z-fuzz
5 bit OUT FALSE input.0.abs-z-is-neg
5 bit OUT FALSE input.0.abs-z-is-pos
5 float IN 127.5 input.0.abs-z-offset
5 float OUT -0.003921569 input.0.abs-z-position
5 float IN 127.5 input.0.abs-z-scale
5 bit OUT FALSE input.0.btn-base
5 bit OUT TRUE input.0.btn-base-not
5 bit OUT FALSE input.0.btn-base2
5 bit OUT TRUE input.0.btn-base2-not
5 bit OUT FALSE input.0.btn-base3
5 bit OUT TRUE input.0.btn-base3-not
5 bit OUT FALSE input.0.btn-base4
5 bit OUT TRUE input.0.btn-base4-not
5 bit OUT FALSE input.0.btn-base5
5 bit OUT TRUE input.0.btn-base5-not
5 bit OUT FALSE input.0.btn-base6
5 bit OUT TRUE input.0.btn-base6-not
5 bit OUT FALSE input.0.btn-joystick
5 bit OUT TRUE input.0.btn-joystick-not
5 bit OUT FALSE input.0.btn-pinkie
5 bit OUT TRUE input.0.btn-pinkie-not
5 bit OUT FALSE input.0.btn-thumb
5 bit OUT TRUE input.0.btn-thumb-not
5 bit OUT FALSE input.0.btn-thumb2
5 bit OUT TRUE input.0.btn-thumb2-not
5 bit OUT FALSE input.0.btn-top
5 bit OUT TRUE input.0.btn-top-not
5 bit OUT FALSE input.0.btn-top2
5 bit OUT TRUE input.0.btn-top2-not
Last edit: 01 Mar 2013 23:34 by no-bug. Reason: double show pin
02 Mar 2013 00:10 #30719 by ArcEye
Hi
This normally occurs where a startup has failed but left modules not properly unloaded, the next time you try to start you get this error.
Your button is now recognised,
so this is a different error.
Reboot to clear everything and try again
02 Mar 2013 00:23 #30722 by andypugh
Replied by andypugh on topic Joystick
Restart the PC. HAL has crashed and left a mess behind.
In theory halrun -U is meant to clean it up, but I have never known it to work.
02 Mar 2013 02:02 #30730 by no-bug
That's quite ok after reboot but.....
The joystick does not act in anyway and no error message!
notice ; the tutorial say "postgui.hal" but I only find a "custom_postgui.hal" in the directory.
Time to create page: 0.127 seconds
