Intel H81
- pmcstoneinc
04 Sep 2014 00:36 #50701
by pmcstoneinc
Intel H81 was created by pmcstoneinc
No love for Intel H81 Express chipset???
- ArcEye
- Thank you received: 758
04 Sep 2014 15:42 #50743
by ArcEye
Replied by ArcEye on topic Intel H81
Assuming you are not a bored Intel employee filling in time, there are 2 here
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
- pmcstoneinc
04 Sep 2014 20:37 #50756
by pmcstoneinc
Replied by pmcstoneinc on topic Intel H81
I have no luck with either the live boot or install. It hangs on both. The live boot just goes through an endless loop. I will provide error message in a bit.
- ArcEye
04 Sep 2014 21:33 #50760
by ArcEye
You will have to tell us exactly what board you have.
The 2 Gigabytes boards on the latency test that give good results are H61 not H81.
(mis-read the number on my first reply)
We are starting to see problems with some manufacturers who make boards expecting windows 8 and are unable to even detect anything else.
Then there is UEFI BIOS, efi boot loaders and gpt disc partitions.
In 'the interests of security', microsoft has persuaded a lot of manufacturers to try and make loading anything but their crap very difficult.
- pmcstoneinc
04 Sep 2014 22:25 #50765
by pmcstoneinc
Here are the specs of the board
us.shuttle.com/barebone/Models/DS81.html
That is all the specs I have on it, their manual is not so hot for documentation, I can tell you there is no UEFI Bios
I have a SSD installed with partitioned windows 7 on it. I was able to do an install and install the GRUB bootloader but during boot up it goes to a flashing cursor, top left screen, as you can tell I am a noob to the Linux community, any help would be greatly appreciated. Thanks.
- ArcEye
05 Sep 2014 02:09 - 05 Sep 2014 02:12 #50785
by ArcEye
Hi
Looks like a laptop in a box, even uses laptop memory modules.
Just curious as to how you are going to connect it, with no parport and just one half size mini PCIe spare
One thing that strikes me is there is immediately a BIOS update available.
Have you done it?
The number of boards released with defective BIOS, closely followed by an update is quite high.
PS
You have not said what it is you are trying to install.
If it is 10.04 try Wheezy and vice versa
Have you done it?
PS
Last edit: 05 Sep 2014 02:12 by ArcEye.
- pmcstoneinc
05 Sep 2014 07:37 #50790
by pmcstoneinc
Its installed,,Wheezy that is but with no luck on running, it will not boot. I was having issues with my wireless keyboard, I had to go to a wired setup just to even install, I get the boot loader select the OS and then I just get a flashing cursor top left. Ctrl/alt/del restarts, and that's all I get. Is there an error log? I will try 10.04 tomorrow, thanks for your help
- ArcEye
05 Sep 2014 13:52 - 05 Sep 2014 14:52 #50797
by ArcEye
I have a nasty feeling of deja-vu here.
The flashing cursor top left indicates you have selected a valid kernel in GRUB and it has attempted to boot.
It is however indicative of a deep incompatibility with kernel.
I have built kernels in the past which have done this and more important, this has been the experience of some users trying to run a rtai kernel on some of the newer chipsets.
There will be no log, it is too early.
If the 10.04 based LiveCD does not produce a running kernel, I would suggest you download the standard Wheezy install iso from the Debian site and try that.
If that runs, I can only suggest you try to get your money back and I will post a big warning on the latency wiki.
You will note there is already one on there about a board that boots rtai but USB etc does not work.
An earlier board would not run rtai at all, but it proved impossible to narrow down the problem as the same chipset was used on lots of boards that ran OK
Last edit: 05 Sep 2014 14:52 by ArcEye.
- pmcstoneinc
05 Sep 2014 22:50 #50813
by pmcstoneinc
10.04 Live, no luck as well, just get a command prompt ubuntu@ubuntu
Which Weezy install do I need? I see like 8 CDs, do I need them all?
Thanks for all your help Arc, greatly appreciated.
- ArcEye
05 Sep 2014 23:03 - 05 Sep 2014 23:03 #50814
by ArcEye
I use the netinstall
280MB and it pulls the rest on your internet connection, so it is always up to date after install
cdimage.debian.org/debian-cd/7.6.0/i386/...6.0-i386-netinst.iso
Last edit: 05 Sep 2014 23:03 by ArcEye.
Time to create page: 0.064 seconds
