Intel H81
- pmcstoneinc
11 May 2015 03:55 - 11 May 2015 04:00 #58544
by pmcstoneinc
Replied by pmcstoneinc on topic Intel H81
Peter I installed 3.14.39 with the ethernet RT patch. I am getting high latencies, 1m ns??? Is this a possible bug or are the numbers legit. Did I miss something in the kernel config when compiling? Let me know. Thanks.
Last edit: 11 May 2015 04:00 by pmcstoneinc.
- Thank you received: 5181
11 May 2015 05:19 #58548
Replied by PCW on topic Intel H81
If you mean the preemt-rt patch, you should get decent latency from a H81
If you did not, its likely you did not set the proper kernel options for a fully preempt-able kernel
freeby.mesanet.com/makert should build the latest preemt-rt kernel
freeby.mesanet.com/rtconfig is a known working .config file
The following user(s) said Thank You: grandixximo, pmcstoneinc
- pmcstoneinc
11 May 2015 05:34 #58550
by pmcstoneinc
Thanks Peter I will look into it. This is on a different system since I retired the H81 for a desktop PC.
- pmcstoneinc
11 May 2015 10:53 #58553
by pmcstoneinc
This worked flawless. Anyway of getting this as a sticky for the 7i92? Thanks again Peter
12 May 2015 01:06 #58569
Note this is not 7I92 specific but just a way to make a up-to date
Preemt-RT kernel on a Debian (Ubuntu, Mint, Debian etc) based system
- pmcstoneinc
12 May 2015 01:08 #58570
by pmcstoneinc
Peter do you have any other documentation on the 7i92 or a possible wiki page? Let me know. Thanks.
Time to create page: 0.070 seconds
