ARM and EMC
- serg_io
24 Dec 2010 08:57 - 24 Dec 2010 08:59 #6236
by serg_io
Replied by serg_io on topic Re:ARM and EMC
Hi!
Yes, I works on this project some time.
1. Kernel 2.6.32 + patch for Timer over FIQ interrupt from Openmoko project. FIQ handler used as STEP DDS and DIR control for 6 axis.
2. EMC 2.2.0 builded in the SIM mode, RTAI is not used. Instead used a dedicated Kernel module to transfer coordinates to FIQ handler via FIFO to avoid kernel delays.
3. Additional EMC2 HAL module to transfer coordinates and GPIO acces via kernel module.
Last edit: 24 Dec 2010 08:59 by serg_io.
- jdx714
24 Dec 2010 14:38 #6241
by jdx714
Replied by jdx714 on topic Re:ARM and EMC
I see you've started a mini RTproccess the timer interrupt FIQ, but I had to create your own controls steppers right?.
Thanks for responding.
I am planning a similar project with an ARM9 400Mhz processor (ATMEL AT91SAM9G45) but my first obstacle on the road is to link the patched kernel for this board with the RTIA.
I'll read some more about FIQ interrupts to see if I can avoid RTIA.
Thanks.
PS: I suck with written English, sorry but continued to use web translators.
Thanks.
- whhenyuan
06 Aug 2014 14:38 #49555
by whhenyuan
Replied by whhenyuan on topic ARM and EMC
I've no experience of that but I have used the mini2440 which they also have on that site:
www.hycshop.com/
Admittedly that's $88 but that includes the LCD screen. The mini2440/micro2440 is a brilliant way to get into ARM9 based Linux
development!
www.hycshop.com/
development!
Time to create page: 0.072 seconds
