Asrock Q1900B-ITX
7 years 7 months ago - 7 years 7 months ago #128130 by Richard J Kinch
Replied by Richard J Kinch on topic Asrock Q1900B-ITX
Literally any DELL Optiplex series with a Pentium 4 or Pentium D, Core, Core2Duo.
Price from 10 to 100 $. Plenty of them on sale, they never fail.
I should have qualified that "available" means something you can buy new, not scrounging around for used items and uncertain logistics.
A LinuxCNC cookbook should not start with, "first catch your hare."
Is the DELL Optiplex Pentium currently on dell.com a "warrant"? But these cost $700 and are desktop cases with fans.
The ASRock Q1900B-ITX sold for about $80. Assembled into a 1U rackmount case with power supply, HDD, and 4GB memory, the ready system totals under $200.
Last edit: 7 years 7 months ago by Richard J Kinch.
7 years 7 months ago #128134 by ississ
Replied by ississ on topic Asrock Q1900B-ITX
tommylight wrote: Literally any DELL Optiplex series with a Pentium 4 or Pentium D, Core, Core2Duo.
I disagree. I have two Dell 775 Core2Duo 3GHz towers and both are bad performers for linuxcnc. Maybe I need to test different memories for those too...
Dell GX270 P4 is really good, I have two of these in linuxcnc use but they are rather old...
Also it would be good to know which NEW board/models to use, not only some 10 year old models even they are still available somewhere...
7 years 7 months ago #128156 by andypugh
Replied by andypugh on topic Asrock Q1900B-ITX
ississ wrote: Also it would be good to know which NEW board/models to use, not only some 10 year old models even they are still available somewhere...
I agree. But new boards don't stay new for long. I know what works in my machines, but I bought them 5+ years ago so they are not current.
I don't know how many LinuxCNC users / developers buy more than one new brand new motherboard a year to keep current with the market.
7 years 7 months ago #128176 by ississ
Yep. But 5+ years ago is new compared to my Dell GX260 (sorry, typo in previous message saying 270) released in 2002 and rescued from being scrapped from work about 2008 or so.
The Fujitsu D8830 that I'm now replacing is "much" newer, I started emc/linuxcnc with it in 2009.
At least here these are not available and there is not much sense shipping them from other countries.
I'm a good example of "Don't touch if it works" and have problems replacing some 10+ year old hardware after 9 years of own use...
I believe many do the same and not upgrade their systems unless needed.
Anyway now I found a new Q1900B-ITX to replace that Fujitsu, let's see how it goes when the old Dells get broken (I have 1 spare waiting so not very soon I hope)...
One possibility is to buy 2 more Q1900 now and put them to wait to be needed. Or upgrade all three now at the same time. But the old ones still work well so...
It would also be interesting to compile 4.something kernel with rtai and see how it performs on newer hardware like J40xx or J41xx. Just have to get the hardware somewhere first ;)
7 years 7 months ago #128308 by ississ
@Richard J Kinch, have you ever checked cpu temperature when running inside the case ?
I understood you don't have any fans there.
I left the board running latency test overnight and the temp stayed at 54C with about 10% idle on the table in open air, room temp about 22-23C.
Just wondering if a fan is needed with a small case...
7 years 7 months ago - 7 years 7 months ago #128338 by Richard J Kinch
ississ wrote: @Richard J Kinch, have you ever checked cpu temperature when running inside the case ? ... Just wondering if a fan is needed with a small case...
I run them in 1U rackmount cases that are entirely closed other than some perforated vents on the narrow front and back. It's very cramped in there, so I suppose that counts as a small case.
My "temperature check" is to touch the top of the case above the CPU heatsink, or the heatsink itself if the top cover happens to be off. This is never more than comfortably warm to the touch, but it feels like a few watts of warmth, indicating that the heat is dissipated by conduction/radiation and not via the slight ventilation.
My 1U setup is not strictly fanless, because the compact power supply has a tiny fan in it, and that pulls a small flow into the front and out the back. What I mean by "fanless" is no fans in the case itself. The 1U case has mount points for tiny fans, but I don't use them.
You can also run these off 12VDC wall-warts, with those little gadgets that make the various voltages on the connector, and in that case you wouldn't even have the power supply fan. Maybe that would trap heat too much.
One of my dogmas is to manage all the electronics from rackmount and DIN-rail hardware. I find this the most efficient and economical way to keep all the complexity under control, reliable, modifiable/improvable/staged, and maintainable.
Time to create page: 0.078 seconds
