Asrock Q1900B-ITX
4 years 2 months ago #250336 by ississ
Replied by ississ on topic Asrock Q1900B-ITX
I used the old rtai version with this board and it worked well.
The problem was that I wanted a newer os version and couldn't get it to work correctly. Latency test was ok but starting linuxcnc always resulted in that unexpected delay.
I solved the situation with another board (Portwell WADE 8012) wchich works well (I have 1 with mesa pci, 2 with mesa eth).
The following user(s) said Thank You: tarasko
4 years 2 weeks ago #254161 by tarasko
Replied by tarasko on topic Asrock Q1900B-ITX
Is there a way to not rely on motherboard latency capabilities and use linuxcnc as software to control some independent hardware module which will generate steps?
4 years 2 weeks ago #254164 by tommylight
4 years 2 weeks ago #254167 by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic Asrock Q1900B-ITX
On an ASRock J3355B-ITX (celeron 2 cores) , I just add a MESA 6i25 to the config to solve latency problems and to remove stepping generation form the motherboard cpu. I have keep the same pinout as the parport.
the 6i25 was available form eusurplus fiew weeks ago. A little expensive with vat and shiping.
4 years 2 weeks ago #254177 by tarasko
And what BASE_PERIOD became after installing this MESA 6i25 ?
4 years 2 weeks ago #254180 by tommylight
Time to create page: 0.308 seconds
