Chromebook and LinuxCNC
9 years 2 months ago - 9 years 2 months ago #98190 by smplc
Replied by smplc on topic Chromebook and LinuxCNC
Should Ubuntu or a Linux OS be installed on a hard drive to boot up Debian LinuxCNC dongle because of Shell?
Last edit: 9 years 2 months ago by smplc.
9 years 2 months ago #98191 by rodw
Replied by rodw on topic Chromebook and LinuxCNC
I downloaded the ISO and copied it to a USB from a windows PC using Win32DiskImager. You need to rename the file extension to .img. Then I booted from USB.
I could never burn an ISO to a USB from Linux. I saw this was a known bug in some distributions.
9 years 1 month ago #99351 by atrox1333
Replied by atrox1333 on topic Chromebook and LinuxCNC
I am thinking of getting one of these for the 7i76e board.
www.gigabyte.com/Mini-PcBarebone/GB-EKi3A-7100-rev-10#ov
9 years 1 month ago #99353 by rodw
You might be able to save some money by using a celeron based machine J1900 or N3160 which is all you need (by Mesa's recommendation. Aso the onboard wifi is pretty useless and most likely will cause unuseable latency so the big antennas will be useless as you'll probably need to use an USB wifi dongle.. If you look around, you should be able to find a similar machine with dual LAN ports and celeron cpu.
5 years 11 months ago #190483 by smplc
Experiencing some difficulty accessing LinuxCNC. It's been about a year since I booted to Debian 9 and opened LinuxCNC Axis a lot of times. Equipped with a Gigabyte GB-BXBT-1900, Ubuntu 16.04 LTS OS and USB Debian 9 Stretch LinuxCNC PREEMP. I think it's the very USB stick before booted to Debian 9. I think upon powering on the computer the BIOS was intercepted with F12 and a selectable boot drive which, is UEFI: USB Flash Memory1.00, enter and sent the GNU GRUB. I was only able to get to the GNU GRUB two out of many times recently and accidently went to Ubuntu instead of Debian 9. I think was suppose to select `C', press any key and boot to Debian. Would you know why not getting to the GNU GRUB screen often enough bye chance?
5 years 11 months ago #190488 by smplc
Optionally resetted the CMOS.
I did get into the GNU GRUB by repeatedly pushing the Shift key upon powering on.
Could of the 'Advance options for Ubuntu' and 'Ubuntu, with Linux 4.10.028-generic' been selected but 'UEFI: USB Flash Memory1.00' didn't send to GNU GRUB. Selecting 'Ubuntu, with Linux 4.10.028-generic' boots to Ubuntu 16.04 LTS OS. The Ubuntu desktop appears okay.
Still can't boot to Debian 9.
