motherboard for linuxcnc uspace + mesa 7i80hd
- vre
- Thank you received: 17
29 Jul 2018 18:19 #115093
by vre
motherboard for linuxcnc uspace + mesa 7i80hd was created by vre
Witch motherboard for linuxcnc uspace + mesa 7i80hd
Asrock J5005-ITX
or
Asrock J4105M (microATX)
Asrock J5005-ITX
or
- Thank you received: 5337
29 Jul 2018 19:59 #115099
Replied by PCW on topic motherboard for linuxcnc uspace + mesa 7i80hd
They are both intel and pretty similar performance wise so I dont think it would make much difference.
- vre
29 Jul 2018 22:29 - 29 Jul 2018 22:30 #115101
by vre
Replied by vre on topic motherboard for linuxcnc uspace + mesa 7i80hd
7i80hd has some requirements from ethernet card ?
For example works with
Realtek RTL8111H / Realtek RTL8111E
Also for touch screen what i must see before order ?
Last edit: 29 Jul 2018 22:30 by vre.
- vre
03 Aug 2018 21:04 #115575
by vre
i got Asrock J4105M (microATX) because has parallel + 2 serial
also 30euros cheaper from j5005-itx .
When i receive i will inform for jitter and if it is suitable for linuxcnc.
- vre
28 Aug 2018 11:46 - 31 Aug 2018 07:12 #116722
by vre
I got asrock J4105M but intel onboard gpu with stock preempt-rt kernel does not work
needs kernel >= 4.18 to work.
Iam building new kernel now
so in 3 hours after compiling finish i will know..
Last edit: 31 Aug 2018 07:12 by vre.
28 Aug 2018 11:49 #116723
Yes, I'm running 4.16 on a couple of test machines
(even 4.18 works though I would not suggest 4.18 for general use yet)
- vre
28 Aug 2018 11:57 - 28 Aug 2018 12:00 #116724
by vre
ok iam building it in debian stretch(stable) with linuxcnc 2.7.14 installed from linuxcnc.org repo..
I have tried 4.18 but rt patch fails to aplied.
I have tried to install 2.7.14 from linuxcnc.org repo to debian sid but fails because is missing 1 depedency
Last edit: 28 Aug 2018 12:00 by vre.
28 Aug 2018 12:06 #116725
You may have a build script error with 4.18
It does build and make a working kernel:
freeby.mesanet.com/8300-4.18.png
missing dependencies are to be expected (and fixed)
- vre
28 Aug 2018 21:14 - 28 Aug 2018 21:27 #116756
by vre
When i apply patch to 4.18.5 it fails here
$ xzcat ../patch-4.18-rc8-rt1.patch.xz | patch -p1
patching file Documentation/driver-api/libata.rst
patching file arch/Kconfig
Hunk #1 succeeded at 20 (offset 3 lines).
patching file arch/alpha/include/asm/spinlock_types.h
patching file init/main.c
Hunk #1 FAILED at 561.
1 out of 1 hunk FAILED -- saving rejects to file init/main.c.rej
$ cat init/main.c.rej
--- init/main.c
+++ init/main.c
@@ -561,6 +561,7 @@ asmlinkage __visible void __init start_kernel(void)
setup_command_line(command_line);
setup_nr_cpu_ids();
setup_per_cpu_areas();
+ softirq_early_init();
boot_cpu_state_init();
smp_prepare_boot_cpu(); /* arch-specific boot-cpu hooks */
--- init/main.c
+++ init/main.c
setup_nr_cpu_ids();
Last edit: 28 Aug 2018 21:27 by vre.
28 Aug 2018 22:52 #116760
I would not expect a patch set for 4.18-rc8 to apply to 4.18.5
Time to create page: 1.267 seconds
