Raspberry Pi 4
7 years 1 month ago #145838 by PCW
Replied by PCW on topic Raspberry Pi 4
My version should not make any difference since it just adds support for the 7C80 and 7C81. I have merged my changes to Berthos new code ( my previous version was using svantegs patch). I have not tested it yet but will try tomorrow.
7 years 1 month ago #145863 by cakeslob
Replied by cakeslob on topic Raspberry Pi 4
I was using a 2.9.0pre , run in place. btu it also looked like i had a 2.8pre run in place, which also didnt load for the same reason. im reloading the image from scratch now so ill see hopw that goes. this is my start up from 2.9
File Name: startup_20...9-22.txt
File Size:1.05 KB
7 years 1 month ago - 7 years 1 month ago #145864 by Bertho
Replied by Bertho on topic Raspberry Pi 4
Do you use my version with a new card? This message looks like it:
hm2_rpspi: Unknown board at SPI0/CE0: MESA7C81
I have not incorporated PCW's changes to support additional boards. That said, the driver loads and communicates up to the point where it detects an unsupported board.
So, if you are using my new driver, then at least it would be confirmed that it can talk to the RPi hardware.
Last edit: 7 years 1 month ago by Bertho.
7 years 1 month ago #145866 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
I've hit a show stopper here. For some reason /media/pi/workspace, a 240GB ssd plugged into a usb3 hub, plugged into a usb3 port, went ro while sitting hot overnight. And now I can't boot a fully functioning rt kernel, its screen is 16 pixels small all the way around, and while the ssd's must be mounting as there's 3 disk icons on this undersized screen, but no mouse or keyboard response. Edit /boot/config.txt to restore the default non-rt boot, and it all works. I'm plumb bumfuzzled, been around this loop about 8 times now and need to fix some lunch for us.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
7 years 1 month ago #145867 by acondit
Replied by acondit on topic Raspberry Pi 4
Do you have a heatsink on your rpi 4b? I have been reading about them running hot and causing some people problems.
Alan
7 years 1 month ago #145871 by Gene1934
got the big 2 piece sandwich w/o the fans from bangood on it, make -j4 doesn't phase it.
Time to create page: 0.076 seconds
