Raspberry Pi 4
7 years 1 month ago #146592 by acondit
Replied by acondit on topic Raspberry Pi 4
I tried again to build linuxcnc-uspace on my rockpro64 but I am getting some errors on
"sudo dpkg -i linuxcnc-uspace_2.8.0~pre1_arm64.deb"
(Reading database ... 185225 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.8.0~pre1_arm64.deb ...
Unpacking linuxcnc-uspace (1:2.8.0~pre1) over (1:2.8.0~pre1) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python-gtksourceview2; however:
Package python-gtksourceview2 is not installed.
linuxcnc-uspace depends on python-vte; however:
Package python-vte is not installed.
linuxcnc-uspace depends on gstreamer1.0-plugins-base; however:
Package gstreamer1.0-plugins-base is not installed.
linuxcnc-uspace depends on python-xlib; however:
Package python-xlib is not installed.
The instructions say:
Now edit debian/control.bottom.in and remove the following lines
python-vte,,
but the lines are not in debian/configure so I can't delete them.
So does anybody have any suggestions??? They are obviously being referenced from somewhere.
7 years 1 month ago #146593 by Chris D
Replied by Chris D on topic Raspberry Pi 4
andypugh wrote:
Chris D wrote: " the 7C80 still needs its inmux firmware module support added to the hostmot2 driver"
What does that mean?
It sounds like the 7C80 uses a Hostmot2 module that is not currently supported by the LinuxCNC driver.
Hostmot2 defines a number of modules, with an identifying code:
github.com/LinuxCNC/linuxcnc/blob/master...tmot2/hostmot2.h#L92
(I suspect that some marked as "not supported" are actually now supported. But "inmux" is not even listed.)
Each GTAG type has its own driver file, for example GTAG 128, led, is handled by led.c
github.com/LinuxCNC/linuxcnc/blob/master.../mesa-hostmot2/led.c
(I chose that one as it is the simplest of them, but all the driver files follow the same structure)
The very first thing I did with LinuxCNC coding was write the tp_pwmgen driver to enable use of the 7i49 card. If you fancy a project....
Thanks for the information Andy. If I only had time for all the projects I have active now:( :(
Chris
7 years 1 month ago - 7 years 1 month ago #146595 by PCW
Replied by PCW on topic Raspberry Pi 4
I have finished the inmux module driver but its not merged into LinuxCNC yet
I have a bunch of new modules, and some additions that are not merged yet
7C80/7C81 Berthos RPI4 fixes+ my 7C80/7C81 support
Offset PWM mode added to PWM module
Inmux module support (7C80, 7I95, 7I97)
(inmux is input multiplexer for Input expansion, adds digital filter on inputs and 4 MPG counters with 1x/4x modes)
7I94, 7I95, 7I97 Ethernet board support
Last edit: 7 years 1 month ago by PCW.
7 years 1 month ago #146597 by Chris D
PCW wrote: I have finished the inmux module driver but its not merged into LinuxCNC yet
If I am interpreting that correctly, that sounds like fantastic news for everyone that wants to use the RPI4 with the 7C80 board. THANK YOU VERY MUCH!
Chri
7 years 1 month ago #146600 by acondit
Well if I could just read. I missed the "edit debian/control.bottom.in". Running the process now.
7 years 1 month ago #146602 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
acondit wrote: Well if I could just read. I missed the "edit debian/control.bottom.in". Running the process now.
Humm, the last time I did that, for a 7i90HD mesa card, I didn't have a debian/control.bottom.in file? What else did I miss?
I am slowly taking 1.6mm off the heat sinks legs because the heat conductive padding I got from Startech is about that much thinner than what came with that covers the whole top of the rpi4 heat sink. There legs are so fragile, I'm going .1mm at a time, sweeping y, then dropping z. At the feeds, almost 4 hours a leg, I could speed it up with a bigger stepover and a deeper cut, but those legs next to the gpio pins are nearly as fragile as a soap bubble. When I remount for the front legs, which are much stouter, I'll double both cuts.
Thank you.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
Time to create page: 0.267 seconds
