Raspberry Pi 4
7 years 3 months ago #140160 by andypugh
Replied by andypugh on topic Raspberry Pi 4
Hakan wrote: Andy was that on raspbian RPi4 or on Intel buster? It seems to me the two are not exactly the same.
RPi4. I am working abroad this week, but I brought the Pi with me, so will have a check tonight.
7 years 3 months ago #140166 by Hakan
Replied by Hakan on topic Raspberry Pi 4
I think I figured out what you did. You replaced rsvg in lathehandler.py?
So it is more LatheMacro than gladevcp.
Slowly understanding all this.
7 years 3 months ago #140178 by andypugh
I haven't tested lathehandler.py.
I would not be surprised to find that it doesn't work, but it is probably an easy fix using gobject introspection. Most other things seem to be.
7 years 3 months ago - 7 years 3 months ago #140248 by andypugh
Hakan wrote: I think I figured out what you did. You replaced rsvg in lathehandler.py?
I feel to be homing in on a solution for the lathe macros, but it isn't all the way there. I think we might need to change all of GladeVCP.
If you
sudo apt-get install gir1.2-rsvg-2.0
Then in a standalone Python session you can
from gi.repository import Rsvg as rsvg
Unfortunately once you are using gi (gobject introspection) it seems that you are not allowed to not use it elsewhere, so if you edit lathehandler.py to use the above, you get:
import error: When using gi.repository you must not import static modules like "gobject". Please change all occurrences of "import gobject" to "from gi.repository import GObject". See: bugzilla.gnome.org/show_bug.cgi?id=709183
Last edit: 7 years 3 months ago by andypugh.
7 years 3 months ago #140249 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
If you
I realize I may be tarred and feathered for the suggestion, but isn't this as good a time as any to switch to working in python-3.7 for any python stuff you have to re-write? From the comments on the python list, python-2.7 is on very limited life support and gasping for air. Only a month or so left. I wish I could help, but python has never yielded to any fixes I've tried such as trying to find a solution for camview going dead just when you've jogged to the second way point to record or fix a workpiece miss-alignment.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
7 years 3 months ago #140252 by Hakan
I would think so too. python never was my tool I am afraid.
But there are long term options and short term.
Short term, it would be good if thís could be made going in some way. buster is knocking on the door.
Long term, I see you are working on Qt stuff and what not. It may take its time but a clear way forward would be really nice to have.
... I'll try your suggestion tomorrow, andy.
Time to create page: 0.215 seconds
