Raspberry Pi 4
6 years 1 month ago #183768 by kramerda
thankyou ..... Iwill try tomorrow (side note - on a third image burn test it would run once and then quit from a reboot as opposed to second round that quit after power down/up. I don't fully understand the iface eth0 inet static above but I will look it up - sounds like as you first suggested I have changing ip address issues.
6 years 1 month ago #183854 by _big_
Below is latency-histogram from my RPi4. I think its usable, but I've seen better posted here.
I did this while running running remote desktop over the on board WiFi. Probably not the best thing. When I actually start using LinuxCNC I will have a dedicated display and keyboard.
I'm using the on board LAN to connect to the 7i92. I've heard that the onboard WiFi can increase latency. I still want internet connectivity.
So, the question is, what's the recommendation for a USB LAN dongle? Traffic on this LAN connection should be light, and if necessary, unused while LinuxCNC is active.
5 years 11 months ago #189723 by PavelChekov
Replied by PavelChekov on topic Raspberry Pi 4
Hello
I write the image for the RPI4 from the LinuxCNC Homepage to the card.
When I Start the rpi I get this error: => see picture
Then it automatically restart an start normal
What is the problem ?
5 years 11 months ago #189728 by Bari
Replied by Bari on topic Raspberry Pi 4
it means that your CPU doesn't support hardware virtualization
help.ubuntu.com/community/KVM/Installation
Not a LCNC problem. Ask the Rpi4 Linux devs.
github.com/raspberrypi/linux/issues/2299
5 years 11 months ago - 5 years 11 months ago #189737 by PavelChekov
Do they use different CPU for the rpi4 ?
Or does all user with an rpi4 have this problem (with this Image from the LCNC HP) ?
Last edit: 5 years 11 months ago by PavelChekov.
5 years 11 months ago #189738 by PCW
Replied by PCW on topic Raspberry Pi 4
I think you just need to disable KVM (or use a kernel that has it disabled)
The warning is harmless
The following user(s) said Thank You: PavelChekov
Time to create page: 0.474 seconds
