Raspberry Pi 4
6 years 1 month ago #182960 by Bari
Replied by Bari on topic Raspberry Pi 4
Should I make a LCNC SD card image with LCNC 2.8 already configured to run a DLP/LCD printer using the Rpi4? I'm not sure how simple this has to be made for hobbyists to be able to use it.
The following user(s) said Thank You: partec
6 years 1 month ago - 6 years 1 month ago #182978 by partec
Replied by partec on topic Raspberry Pi 4
i think that would be fine
i have installed it with JT's
gnipsel.com/linuxcnc/uspace/rpi4-rt.html
my question remains how to manage GPIO configuration in detail?
Last edit: 6 years 1 month ago by partec.
6 years 1 month ago #182998 by Bari
You don't have to install using all the steps at JT's site anymore. There is a full working SDcard image on the wiki now.
LinuxCNC 2.8.0 Raspberry Pi OS based on Debian 10 Buster
www.linuxcnc.org/iso/linuxcnc-2.8.0-pi4.zip
Raspberry Pi 4 Uspace compatible with Mesa Ethernet and SPI interface boards.
A StepConfig app could be written for Rpi4.
6 years 1 month ago #183066 by partec
thank you Bari, what does this exactly mean, please, a StepConfig app could be written for Rpi4?
6 years 1 month ago #183068 by Bari
For x86 we have linuxcnc.org/docs/html/config/stepconf.html
Stepconf is a program that generates configuration files for LinuxCNC for a specific class of CNC machine: those that are controlled via a standard parallel port, and controlled by signals of type step & direction.
Stepconf is installed when you install LinuxCNC and is in the CNC menu.
A similar app could be written for the Rpi to configure GPIO's and test them.
6 years 1 month ago - 6 years 1 month ago #183074 by partec
Yes, thank you, this Stepconf i know.
I am looking for something like
erste.de/rasPiCat.html
how to configure Raspberry PI4 GPIO to use it as it is like the parallel ports, say ini and hal configuration
Time to create page: 0.081 seconds
