Thorhian wrote: Thank you Helioz.
Right now I'm just trying to figure out how to power the board and my RPi4.
The Pi doesn't have a set of 5V terminals for power, it has the USB-C (or older microUSB) port and the 40pin header.
Powering the 7C81 via the Pi is theoretically possible but not very practical.
Powering the Pi via the USB connector is marginal at the best of times and I certainly wouldn't want to draw even more current though the Pi into the 7C81 and possibly more Mesa IO boards.
The 40pin header is used to connect the 7C81 so isn't really available for power supply.
The 7C81 on the other hand has proper 5V terminals which are capable of supplying power not only to the 7C81 but also to Pi and Mesa IO modules.
The Pi is a power hungry beast and it's peak power draw is between 1-2A, especially when using WiFi. It is common for Pi's to suffer from Voltage drop when powered via the [older] microUSB ports ..... and that's without any additional periphery. Trust me, I've had plenty of low voltage alarms on my other Pi's and I generally try to avoid powering them via the old microUSB as these interfaces are simply not designed to carry the current required by the Pi.
My linuxCNC Pi is supplied via the 7C81 from a 5V 3A power supply and has never suffered "low voltage" issues.
