- Thank you received: 10
PCW wrote:
COlger81 wrote: Peter,
Assuming that i can get the latency issues worked out. Do you see any issues running Pi4 4gb reliably with ethernet based Mesa boards and PWM signal generation?
I have not done much work with the RPI4 over Ethernet, just SPI.
Forum member skunkworks has been running a RPI4 with a 7I92 for a few
Months now and I don't believe he has any major issues _but_
he did need to run the servo thread at 2 ms (500 Hz) rather than
the standard 1 ms (1 KHz). This may or may not be an issue depending
on the required acceleration. I have been running SPI based cards at 1 KHz
without issue, though you cannot get away with running videos at the same
time as LinuxCNC is running.
blazini36 wrote: That's interesting. Is the SPI interface "generic" meaning that it's not specific to the rpi?
