Raspberry Pi 4 & MESA 7i92
- Mike29
- Thank you received: 3
26 Jan 2020 19:33 #155837
by Mike29
Replied by Mike29 on topic Raspberry Pi 4 & MESA 7i92
I'll continue to show my ignorance as now I am trying to install the 7i92 bit file for the g540x2d and receive the following message
.pi@cnc:~ $ mesaflash --addr 10.10.10.10 --device 7I92 --write G540X2D.BIT
Can't find file G540X2D.BIT
Is there a special process for installing the bit files as this does not seem clear in the HOSTMOT2 documentation?
Thank you
Thank you
The following user(s) said Thank You: cngbrick
- Thank you received: 5328
26 Jan 2020 19:45 #155839
Replied by PCW on topic Raspberry Pi 4 & MESA 7i92
You would need to download the 7i92.zip file from mesa, unzip it and run the mesaflash command from the directory containing the appropriate bit file
- Mike29
27 Jan 2020 16:00 #155925
by Mike29
Thank you but no joy. I did navigate to the folder with the BIT file and ran mesa flash. Still no file found.
pi@cnc:~/emc/src/mesaflash/7i92/configs/hostmot2 $ mesaflash --addr 10.10.10.10 --device 7I92 --write G540X2D.BIT
Any advice appreciated-
27 Jan 2020 16:25 #155930
In linux file name case is significant
- Mike29
27 Jan 2020 16:31 #155931
by Mike29
Thank you, I noticed the case difference after I submitted my previous note. It appears to have loaded successfully/ Thanks again for the help-
mesaflash --addr 10.10.10.10 --device 7I92 --write 7i92_G540x2D.bit
Checking file... OK
File type: BIT file
Boot sector OK
EEPROM sectors to write: 6, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
|EEEEEE
Programming EEPROM sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
Checking file... OK
File type: BIT file
Boot sector OK
|EEEEEE
Checking file... OK
File type: BIT file
Boot sector OK
- ajsinfotech
08 Feb 2020 16:54 #156769
by ajsinfotech
Replied by ajsinfotech on topic Raspberry Pi 4 & MESA 7i92
Hi PCW
How can I install mesaflash on my Rpi3?
I surf the web but there is no relevant info about it.
sudo apt-get install mesaflash seems not to be on Rpi3 packages.
Maybe do I have to install it from source?
Any info is welcome.
Thanks in advance.
Thanks in advance.
08 Feb 2020 19:33 #156775
- ajsinfotech
09 Feb 2020 12:09 #156868
by ajsinfotech
Many thanks PCW!
I figured it out and after some searches I finally found this link:
github.com/micges/mesaflash (I posted just in case)
I could build it fine. When I run the command it states:
Mesaflash version 3.3.0~pre (built on Feb 8 2020 14:20:13 with libpci 3.5.2)
Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB boards
(C) 2013-2015 Michael Geszkiewicz (contact: This email address is being protected from spambots. You need JavaScript enabled to view it.)
I suppose it will work fine.
- twoflowers
- Visitor
12 Feb 2020 08:46 #157141
by twoflowers
Replied by twoflowers on topic Raspberry Pi 4 & MESA 7i92
And, did it work fine on the RPi3?
- ajsinfotech
12 Feb 2020 17:07 - 12 Feb 2020 17:08 #157194
by ajsinfotech
Well... maybe I am a newbie in Mesa card matters, but AFAIK the Mesa docs are very poor and sometimes wrong.
This command from the 7c81 manual is wrong:
./mesaflash --device 7c81 --addr /dev/spidev0.0 --write 7c81_5abobx2d.bit
After contact Mesa Electronics a guy told me that it is wrong. I have to try this:
./mesaflash --device 7c81 --addr /dev/spidev0.0 --spi --readhmid
But this command does not flash the firmware on the board as the manual states, it just query the default board configuration I think.
Is there any tutorial to fully configure a Mesa 7c81 for LinuxCNC?
Thanks!
Thanks!
Last edit: 12 Feb 2020 17:08 by ajsinfotech.
Time to create page: 0.251 seconds
