Raspberry Pi 4 & MESA 7i92
13 Feb 2020 21:31 #157326 by PCW
Replied by PCW on topic Raspberry Pi 4 & MESA 7i92
The SPI errors are expected with a long cable.
You can set the SPI clock frequencies in the driver command line
(man hm2_rpspi)
"Note: Using POSIX non-realtime"
This means you are not running a real time kernel so you need to install a real time kernel on your RPI before LinuxCNC will run reliably
14 Feb 2020 01:11 - 14 Feb 2020 01:12 #157331 by ajsinfotech
Replied by ajsinfotech on topic Raspberry Pi 4 & MESA 7i92
Thanks PCW!
(man hm2_rpspi)
Ok. Now I try to lower the spi clock. But then I'll do what you suggest
I have already installed the rt-kernel. :blink:
I think this note was referred to a non-realtime module running (may be display/keyboard devices, I don't know).
I didn't realize that linuxcnc was not using real-time by issuing this message.
How could I check if the linuxcnc is using all the real-time capabilities?
Thanks!
Last edit: 14 Feb 2020 01:12 by ajsinfotech.
14 Feb 2020 03:21 #157335 by PCW
You can check if you really have a real time kernel installed with
uname -a
14 Feb 2020 13:34 #157356 by ajsinfotech
Thanks PCW!
uname -a
Ok, I know about this command, and I check it several times as I build the rt.
I'm not with my toy right now. I'll send you my kernel version later, just in case.
So, I don't know why linuxcnc send this message. That's why I ask you for another kind of check, maybe some linuxcnc tool to dig internals.
Another hint: I built linuxcnc from source (2.9 master)
Thanks a lot!
14 Feb 2020 14:29 #157358 by PCW
Did you build the uspace version of LinuxCNC?
The only time I have seen the "Note: Using POSIX non-realtime"
message is when I have run LinuxCNC on a non-RT kernel.
Here is what I normally get (LinuxCNC 2.9 uspace with different hardware):
peter@pcw-HP-EliteDesk-800-G1-USDT:~/linuxcnc-dev/scripts$ linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/peter/linuxcnc/configs'
Machine configuration file is '7i96masterpe.ini'
Starting LinuxCNC...
Found file(REL): ./hm2-pidstepper-master-pe.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:00:02
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Low Level init 0.15
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0: IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0: IO Pin 001 (TB3-02): IOPort
20 Feb 2020 21:29 - 20 Feb 2020 21:35 #158064 by ajsinfotech
Thanks PCW!
I had an issue with the RT, now solved :)
Now on the road again, I have this error:
Machine configuration directory is '/home/pi/linuxcnc/configs/gmoccapy-rpi3-mesa-mill-v1.0.1'
Machine configuration file is 'gmoccapy-rpi3-mesa-mill-v1.0.1.ini'
Found file(REL): ./gmoccapy-rpi3-mesa-mill-v1.0.1.hal
hm2_rpspi: Unknown board at SPI0/CE0: MESA7C81
hm2_rpspi: rtapi_app_main: Operation not permitted (-1)
./gmoccapy-rpi3-mesa-mill-v1.0.1.hal:30: waitpid failed /home/pi/linuxcnc/bin/rtapi_app hm2_rpspi
./gmoccapy-rpi3-mesa-mill-v1.0.1.hal:30: /home/pi/linuxcnc/bin/rtapi_app exited without becoming ready
./gmoccapy-rpi3-mesa-mill-v1.0.1.hal:30: insmod for hm2_rpspi failed, returned -1
hm2_rpspi: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hm2: unloading
<commandline>:0: unloadrt failed
I test the connectivity with the 7c81 and it is ok.
I also see this link:
forum.linuxcnc.org/18-computer/36879-raspberry-pi-4?start=170
But it seems not to be the same case, I think.
Thanks!
Last edit: 20 Feb 2020 21:35 by ajsinfotech.
20 Feb 2020 22:23 #158065 by PCW
If the 7C81 is not recognized it means that you need o update your LinuxCNC installation to the latest. The unable to load issue might be because there are still modules loaded when you launch LinuxCNC, sometimes this takes a reboot to fix.
Here's what I get with recent 2.9 and a 7C81 on a RPI4:
Machine configuration directory is '/home/pi'
Machine configuration file is '7c81-1k.ini'
emc/iotask/ioControl.cc 701: can't load tool table.
Found file(REL): ./hm2-pidstepper.hal
hm2/hm2_7c81.0: Low Level init 0.15
hm2/hm2_7c81.0: Smart Serial Firmware Version 43
hm2/hm2_7c81.0: 57 I/O Pins used:
hm2/hm2_7c81.0: IO Pin 000 (P1-01): IOPort
hm2/hm2_7c81.0: IO Pin 001 (P1-02): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7c81.0: IO Pin 002 (P1-03): StepGen #0, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 003 (P1-04): IOPort
hm2/hm2_7c81.0: IO Pin 004 (P1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 005 (P1-06): IOPort
hm2/hm2_7c81.0: IO Pin 006 (P1-07): StepGen #1, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 007 (P1-08): IOPort
hm2/hm2_7c81.0: IO Pin 008 (P1-09): StepGen #1, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 009 (P1-11): StepGen #2, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 010 (P1-13): StepGen #2, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 011 (P1-15): IOPort
hm2/hm2_7c81.0: IO Pin 012 (P1-17): IOPort
hm2/hm2_7c81.0: IO Pin 013 (P1-19): Encoder #0, pin A (Input)
hm2/hm2_7c81.0: IO Pin 014 (P1-21): Encoder #0, pin B (Input)
hm2/hm2_7c81.0: IO Pin 015 (P1-23): Encoder #0, pin Index (Input)
hm2/hm2_7c81.0: IO Pin 016 (P1-25): IOPort
hm2/hm2_7c81.0: IO Pin 017 (J5-TX0): IOPort
hm2/hm2_7c81.0: IO Pin 018 (J6-TX1): IOPort
hm2/hm2_7c81.0: IO Pin 019 (P2-01): IOPort
hm2/hm2_7c81.0: IO Pin 020 (P2-02): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7c81.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7c81.0: IO Pin 022 (P2-04): IOPort
hm2/hm2_7c81.0: IO Pin 023 (P2-05): IOPort
hm2/hm2_7c81.0: IO Pin 024 (P2-06): IOPort
hm2/hm2_7c81.0: IO Pin 025 (P2-07): IOPort
hm2/hm2_7c81.0: IO Pin 026 (P2-08): IOPort
hm2/hm2_7c81.0: IO Pin 027 (P2-09): IOPort
hm2/hm2_7c81.0: IO Pin 028 (P2-11): IOPort
hm2/hm2_7c81.0: IO Pin 029 (P2-13): IOPort
hm2/hm2_7c81.0: IO Pin 030 (P2-15): IOPort
hm2/hm2_7c81.0: IO Pin 031 (P2-17): IOPort
hm2/hm2_7c81.0: IO Pin 032 (P2-19): IOPort
hm2/hm2_7c81.0: IO Pin 033 (P2-21): IOPort
hm2/hm2_7c81.0: IO Pin 034 (P2-23): IOPort
hm2/hm2_7c81.0: IO Pin 035 (P2-25): IOPort
hm2/hm2_7c81.0: IO Pin 036 (J5-TXEN0): IOPort
hm2/hm2_7c81.0: IO Pin 037 (J6-TXEN1): IOPort
hm2/hm2_7c81.0: IO Pin 038 (P7-01): IOPort
hm2/hm2_7c81.0: IO Pin 039 (P7-02): IOPort
hm2/hm2_7c81.0: IO Pin 040 (P7-03): IOPort
hm2/hm2_7c81.0: IO Pin 041 (P7-04): IOPort
hm2/hm2_7c81.0: IO Pin 042 (P7-05): IOPort
hm2/hm2_7c81.0: IO Pin 043 (P7-06): IOPort
hm2/hm2_7c81.0: IO Pin 044 (P7-07): IOPort
hm2/hm2_7c81.0: IO Pin 045 (P7-08): IOPort
hm2/hm2_7c81.0: IO Pin 046 (P7-09): IOPort
hm2/hm2_7c81.0: IO Pin 047 (P7-11): IOPort
hm2/hm2_7c81.0: IO Pin 048 (P7-13): IOPort
hm2/hm2_7c81.0: IO Pin 049 (P7-15): IOPort
hm2/hm2_7c81.0: IO Pin 050 (P7-17): IOPort
hm2/hm2_7c81.0: IO Pin 051 (P7-19): IOPort
hm2/hm2_7c81.0: IO Pin 052 (P7-21): IOPort
hm2/hm2_7c81.0: IO Pin 053 (P7-23): IOPort
hm2/hm2_7c81.0: IO Pin 054 (P7-25): IOPort
hm2/hm2_7c81.0: IO Pin 055 (P5-RX0): IOPort
hm2/hm2_7c81.0: IO Pin 056 (P6-RX1): IOPort
hm2/hm2_7c81.0: registered
note: MAXV max: 30.000 units/sec 1800.000 units/min
note: LJOG max: 30.000 units/sec 1800.000 units/min
note: LJOG default: 30.000 units/sec 1800.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
21 Feb 2020 15:05 #158138 by ajsinfotech
Thanks PCW!
I have installed the 2.9 release, but the 7c81 card maybe need the latest update.
I'll update LinuxCNC to the last revision as you recommend.
Thanks!
04 Mar 2020 13:24 - 04 Mar 2020 14:29 #159190 by ajsinfotech
Hi PCW
I try to install LinuxCNC from source on my RPi3 from this guide with just a minor changes:
gnipsel.com/linuxcnc/uspace/rpi4-emc.html
But when I run:
debuild -uc -us
I get the following error:
virtual memory exhausted: Cannot allocate memory
Makefile:227: recipe for target 'objects/emc/rs274ngc/interp_python.o' failed
make[1]: *** [objects/emc/rs274ngc/interp_python.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/home/pi/emc/src'
debian/rules:31: recipe for target 'build-stamp' failed
make: *** [build-stamp] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
debuild: fatal error at line 1116:
dpkg-buildpackage -rfakeroot -us -uc failed
My changes:
1 - I checkout this:
git checkout master
instead of:
git checkout 2.8
2 - I did not need to modify debian/configure, it was ok:
Debian-10|Debian-10.*|Raspbian-10|Raspbian-10.*)
Or maybe do I have to change this to:
Debian-10|Debian-10.*|Raspbian-9|Raspbian-9.*) :dry:
3 - I did not remove the following lines from debian/control.bottom.in. I chose to keep it original just in case:
python-gtksourceview2,
python-vte,
Maybe do I have to remove this lines to my RPi3? :dry:
4 - When I run:
debian/configure uspace
It reports this:
successfully configured for 'uspace-Raspbian-9.11'-'uspace'...
instead of:
successfully configured for 'uspace-Raspbian-10'-'uspace'...
Could the Raspbian-9.11 be the problem? :dry:
Or maybe is the RPi3 virtual memory not enough? :unsure:
I try all this exactly on my RPi4 and everything runs fine! :)
Thanks!
Last edit: 04 Mar 2020 14:29 by ajsinfotech.
05 Mar 2020 20:41 #159278 by andypugh
Replied by andypugh on topic Raspberry Pi 4 & MESA 7i92
It may be that the issue is a lack of non-virtual memory. How much RAM does your Pi have?
I am not sure if the pi swaps to SD card, I can imagine that not being a great idea.
