Raspberry Pi 4 & MESA 7i92
6 years 9 months ago #155925 by Mike29
Replied by Mike29 on topic Raspberry Pi 4 & MESA 7i92
Thank you but no joy. I did navigate to the folder with the BIT file and ran mesa flash. Still no file found.
pi@cnc:~/emc/src/mesaflash/7i92/configs/hostmot2 $ mesaflash --addr 10.10.10.10 --device 7I92 --write G540X2D.BIT
Can't find file G540X2D.BIT
Any advice appreciated-:)
6 years 9 months ago #155930 by PCW
Replied by PCW on topic Raspberry Pi 4 & MESA 7i92
In linux file name case is significant
6 years 9 months ago #155931 by Mike29
Thank you, I noticed the case difference after I submitted my previous note. It appears to have loaded successfully/ Thanks again for the help-:)
mesaflash --addr 10.10.10.10 --device 7I92 --write 7i92_G540x2D.bit
Checking file... OK
File type: BIT file
Boot sector OK
EEPROM sectors to write: 6, max sectors in area: 16
Erasing EEPROM sectors starting from 0x100000...
|EEEEEE
Programming EEPROM sectors starting from 0x100000...
|WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
Board configuration updated successfully.
Checking file... OK
File type: BIT file
Boot sector OK
Verifying EEPROM sectors starting from 0x100000...
|VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Board configuration verified successfully.
You must power cycle the hardware or use the --reload command to load a new firmware.
6 years 8 months ago #156769 by ajsinfotech
Hi PCW
How can I install mesaflash on my Rpi3?
I surf the web but there is no relevant info about it.
sudo apt-get install mesaflash seems not to be on Rpi3 packages.
Maybe do I have to install it from source?
Any info is welcome.
Thanks in advance.
6 years 8 months ago #156775 by PCW
Yes, you can build from source:
github.com/jethornton/mesaflash
6 years 8 months ago #156868 by ajsinfotech
Many thanks PCW!
I figured it out and after some searches I finally found this link:
github.com/micges/mesaflash (I posted just in case)
I could build it fine. When I run the command it states:
Mesaflash version 3.3.0~pre (built on Feb 8 2020 14:20:13 with libpci 3.5.2)
Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB boards
(C) 2013-2015 Michael Geszkiewicz (contact: micges@wp.pl)
I suppose it will work fine.
Time to create page: 0.079 seconds
