Hi people,
With the last problem solved. Now a run into this one:
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/pi/emc/configs/gmoccapy-rpi3-mesa-mill-v1.0.1'
Machine configuration file is 'gmoccapy-rpi3-mesa-mill-v1.0.1.ini'
Starting LinuxCNC...
Found file(REL): ./gmoccapy-rpi3-mesa-mill-v1.0.1.hal
Note: Using POSIX realtime
motmod: already exists
hm2/hm2_7c81.0: Low Level init 0.15
hm2/hm2_7c81.0: Smart Serial Firmware Version 43
hm2/hm2_7c81.0: 57 I/O Pins used:
hm2/hm2_7c81.0: IO Pin 000 (P1-01): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7c81.0: IO Pin 001 (P1-02): IOPort
hm2/hm2_7c81.0: IO Pin 002 (P1-03): StepGen #0, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 003 (P1-04): IOPort
hm2/hm2_7c81.0: IO Pin 004 (P1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 005 (P1-06): IOPort
hm2/hm2_7c81.0: IO Pin 006 (P1-07): StepGen #1, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 007 (P1-08): IOPort
hm2/hm2_7c81.0: IO Pin 008 (P1-09): StepGen #1, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 009 (P1-11): StepGen #2, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 010 (P1-13): StepGen #2, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 011 (P1-15): StepGen #3, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 012 (P1-17): StepGen #3, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 013 (P1-19): IOPort
hm2/hm2_7c81.0: IO Pin 014 (P1-21): Encoder #0, pin A (Input)
hm2/hm2_7c81.0: IO Pin 015 (P1-23): Encoder #0, pin B (Input)
hm2/hm2_7c81.0: IO Pin 016 (P1-25): Encoder #0, pin Index (Input)
hm2/hm2_7c81.0: IO Pin 017 (J5-TX0): IOPort
hm2/hm2_7c81.0: IO Pin 018 (J6-TX1): IOPort
hm2/hm2_7c81.0: IO Pin 019 (P2-01): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7c81.0: IO Pin 020 (P2-02): IOPort
hm2/hm2_7c81.0: IO Pin 021 (P2-03): StepGen #4, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 022 (P2-04): IOPort
hm2/hm2_7c81.0: IO Pin 023 (P2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 024 (P2-06): IOPort
hm2/hm2_7c81.0: IO Pin 025 (P2-07): StepGen #5, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 026 (P2-08): IOPort
hm2/hm2_7c81.0: IO Pin 027 (P2-09): StepGen #5, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 028 (P2-11): StepGen #6, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 029 (P2-13): StepGen #6, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 030 (P2-15): StepGen #7, pin Step (Output)
hm2/hm2_7c81.0: IO Pin 031 (P2-17): StepGen #7, pin Direction (Output)
hm2/hm2_7c81.0: IO Pin 032 (P2-19): IOPort
hm2/hm2_7c81.0: IO Pin 033 (P2-21): Encoder #1, pin A (Input)
hm2/hm2_7c81.0: IO Pin 034 (P2-23): Encoder #1, pin B (Input)
hm2/hm2_7c81.0: IO Pin 035 (P2-25): Encoder #1, pin Index (Input)
hm2/hm2_7c81.0: IO Pin 036 (J5-TXEN0): IOPort
hm2/hm2_7c81.0: IO Pin 037 (J6-TXEN1): IOPort
hm2/hm2_7c81.0: IO Pin 038 (P7-01): IOPort
hm2/hm2_7c81.0: IO Pin 039 (P7-02): IOPort
hm2/hm2_7c81.0: IO Pin 040 (P7-03): IOPort
hm2/hm2_7c81.0: IO Pin 041 (P7-04): IOPort
hm2/hm2_7c81.0: IO Pin 042 (P7-05): IOPort
hm2/hm2_7c81.0: IO Pin 043 (P7-06): IOPort
hm2/hm2_7c81.0: IO Pin 044 (P7-07): IOPort
hm2/hm2_7c81.0: IO Pin 045 (P7-08): IOPort
hm2/hm2_7c81.0: IO Pin 046 (P7-09): IOPort
hm2/hm2_7c81.0: IO Pin 047 (P7-11): IOPort
hm2/hm2_7c81.0: IO Pin 048 (P7-13): IOPort
hm2/hm2_7c81.0: IO Pin 049 (P7-15): IOPort
hm2/hm2_7c81.0: IO Pin 050 (P7-17): IOPort
hm2/hm2_7c81.0: IO Pin 051 (P7-19): IOPort
hm2/hm2_7c81.0: IO Pin 052 (P7-21): IOPort
hm2/hm2_7c81.0: IO Pin 053 (P7-23): IOPort
hm2/hm2_7c81.0: IO Pin 054 (P7-25): IOPort
hm2/hm2_7c81.0: IO Pin 055 (P5-RX0): IOPort
hm2/hm2_7c81.0: IO Pin 056 (P6-RX1): IOPort
hm2/hm2_7c81.0: registered
Found file(REL): ./custom.hal
[TASK] CYCLE_TIME not found in /home/pi/emc/configs/gmoccapy-rpi3-mesa-mill-v1.0.1/gmoccapy-rpi3-mesa-mill-v1.0.1.ini; using default 0.100000
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
Waiting for component 'inihal' to become ready..............USRMOT: ERROR: command timeout
Any idea?
I also tried to use pncconf just in case, but it doesn't even works. It throws the following warning and of course my board configuration does not appear in the list (7c81) :S :
You have no hostmot2 firmware downloaded in folder:
/lib/firmware/hm2/
PNCconf will use internal firmware data
Besides, I don't know how to set my board in the pncconf. I was googling but didn't find any clue.
Thanks!
