New Hardware (solved)
02 Mar 2020 13:43 #158967
With some cards setting them to EPP increases the drive current. But I suspect that only applies to motherboard ports where the setting is in the BIOS.
Replied by andypugh on topic New Hardware
Why do you think that? The only issue I've ever had with a parallel card only partially working had to do with internal pull ups not working righ
- stefano
13 Mar 2020 17:27 #160057
by stefano
Replied by stefano on topic New Hardware
I am waiting for a new card, we will see how it works.
thanks for all the advice.
- stefano
18 Mar 2020 16:52 #160661
by stefano
Solved.
Today the new card has arrived but unfortunately it behaves like the old one.
On the net I found a post with my same problem and the advice: "try another pci slot" ......... and everything now works, even with all 4 active processors.
thanks anyway for your patience
- Thank you received: 1480
18 Mar 2020 17:38 #160665
Replied by Todd Zuercher on topic New Hardware
Glad you got it figured out.
Frustrating when so much time is wasted on something so simple. Probably just some dirt in the slot, plugging it in and out a few times may have fixed it.
- Thank you received: 5330
18 Mar 2020 22:17 - 18 Mar 2020 22:17 #160683
Replied by PCW on topic New Hardware
PCI slots, especially vacant slots on older motherboards may be well coated with a many years accumulation of dust and grime.
A fairly easy way to clean these is to liberally apply 99% Isopropyl alcohol
to the new cards board edge connector and insert and remove the card about 5 times,
then wipe the new cards board edge connector and let the alcohol evaporate from the
motherboard before powering on again.
( Beware, 99 % IPA is very flammable so make sure all alcohol and vapors are gone before
powering up the system )
Last edit: 18 Mar 2020 22:17 by PCW.
The following user(s) said Thank You: silden
- stefano
22 Mar 2020 16:31 #161118
by stefano
Replied by stefano on topic New Hardware (solved)
I tried to clean the connector but nothing changes.
The non-working slot is a PCI-e x16 (wire x4) like the LPT card, while the working one is wired x16.
Take a big hammer .........
Time to create page: 0.326 seconds
