RT-Kernel wth MESA-Card?
19 Feb 2020 09:56 #157821 by harvey
RT-Kernel wth MESA-Card? was created by harvey
Hi
I have an understanding problem.
Do I still need an RT kernel if I use MESA cards? The stepping is now generated on the MESA card and therefore the latency on the motherboard should not matter.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
19 Feb 2020 10:05 #157823 by BeagleBrainz
Replied by BeagleBrainz on topic RT-Kernel wth MESA-Card?
Yes real time is required, when controlling a machine
The only time real time is not need is when running a simulator ie: not controlling a machine.
19 Feb 2020 10:12 #157825 by tommylight
Replied by tommylight on topic RT-Kernel wth MESA-Card?
Hi
For PCI and PCI-E cards RTAI and RT-Preempt will work just fine, and latency is not much of an issue within reason, so 100000 is ok. I have used computers with much worse latency for testing.
For the ethernet boards, you do need the Preempt-RT version. Again, latency not a big issue.
The following user(s) said Thank You: harvey
19 Feb 2020 10:57 #157834 by harvey
Replied by harvey on topic RT-Kernel wth MESA-Card?
Hi
Thanks for your quick replies.
The background for my question is the following.
At the moment I have a hobby-mill with a running linuxcnc.
I use an extra computer with a parallel interface to steer my mill.
This computer gets older and sometimes it will strike. I hoped that I can use my Desktop-PC with an ethernet MESA-card
as backup Computer. But my desktop computer has a modern linux without rt-kernel. I thing I have to buy a new mobo when my old computer will die.:(
Best regards
werner
19 Feb 2020 11:56 #157843 by tommylight
forum.linuxcnc.org/9-installing-linuxcnc...ith-linuxcnc?start=0
Modern Linux with modern RT and RTAI kernels.
Time to create page: 0.165 seconds
