Dell Optiplex 9020 Latency Issues
25 Mar 2020 13:15 #161425 by ElBarto
Dell Optiplex 9020 Latency Issues was created by ElBarto
I have Dell Optiplex 9020 USFF (ultra small form factor) with a i5-4590S, on which I want to run Linux CNC with a Mesa ethernet card.
latency-test shows the following results while stress testing with six glxgears, firefox+youtube and firefox+surfing
1ms Thread : 20921ns jitter
25us Thread: 33322ns jitter
As far as I have read this should be sufficient for a mesa card. But latency-test also shows Unexpected real time error
Can this error be ignored? Is this unexpected real time error reflected in the jitter values or is so bad that is not logged anymore in jitter values?
Kernel 4.9.0-12-rt-am64
As much as possible turned off in the BIOS.
Bootparameters: quiet isolcpus=2,3 intel_idle.max_cstate=1 processor.max_csate=1 idle=poll usbcore.autosuspend=-1 mitigations=off nowatchdog nomce
Mitigations I turned off because I think this is useless for a CNC machine.
nowatchdog and nomce reduced the number of machine check exception and non maskable interrupts to zero.
usbcore.autosuspend=-1 because dmesg shows says that usb power management may be unreliable
Another thing that concerns me is that dmesg says ENERGY_PERF_BIAS: Set to 'normal' was 'performance'.
Is this a problem, if so how can I turn it off?
Is there anything else I could do to reduce latency?
25 Mar 2020 15:11 #161454 by PCW
Replied by PCW on topic Dell Optiplex 9020 Latency Issues
The real time error is likely because you cannot run a 40 KHz base thread on that machine
a better test would be with only a servo thread:
latency-test 1ms 1ms
or
latency-histogram --nobase --sbinsize 250
Time to create page: 0.076 seconds
