Upgrading
- Chipmunk
27 Mar 2020 01:01 #161649
by Chipmunk
Upgrading was created by Chipmunk
I am running Ubuntu 10,04LTS on my machine. My Linux CNC is EMC2 , 2.4.6 I would, like to upgrade to a newer addition, but before I do I would like to get some answers to few questions.
My machine is running Windows XP and has 15.9 GB of memory 3.3 of it is used and the other 12.5 is available for programs. When I run a latency test I have no problem meeting the prerequisite for reliable operation..
Would it be the best if I were to start with a fresh download of Linux and also LinuxCNC?
Or would it be better if I were to upgrade what I have? If I go this route can I go to the latest edition or will I have to step through a couple of upgrades?
What flavour of Linux would be the best for my hardware?
- BeagleBrainz
- Visitor
27 Mar 2020 01:30 #161651
by BeagleBrainz
Replied by BeagleBrainz on topic Upgrading
First of all some idea of your hardware would be a good start. Then a recommendation can be made.
The XP machine and the Ubuntu machine are they the same or different machines, that was not quite clear.
So if you can supply a good breakdown of your hardware we can go from there.
1 being the existing machine
2 being the XP machine (if they aren't the same)
3 being whether you are using the Parallel Port or Mesa Hardware
The simplest route would be an install using the official debian based images or you may want to look here forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
The first page list the releases from most recent to oldest.
Some people feel more comfortable with Mint others with Debian.
- Chipmunk
27 Mar 2020 16:00 #161713
by Chipmunk
Replied by Chipmunk on topic Upgrading
Thanks for your reply. Yes Ubuntu and XP are the same machine. I am not using Mesa hardware.
- BeagleBrainz
- Visitor
27 Mar 2020 16:47 #161720
by BeagleBrainz
Ok that's a start.
Now to advise which is the best option a description of MB or computer, including CPU and installed memory will help as well. Saves me having to search for the MB or computer model then trying to guess what cpu you have.
If you machine does not have a 64 bit capable cpu wheezy maybe your best choice.
- Chipmunk
27 Mar 2020 17:39 #161725
by Chipmunk
Thank You for the reply, the machine has 15 GB memory 3 are being used leaving 12 available. As for the other question answers I will have to look at the machine info and get back to you.
- BeagleBrainz
- Visitor
27 Mar 2020 21:29 #161756
by BeagleBrainz
Is that total memory or installed RAM plus swap ?
How much RAM is physically installed ?
- Chipmunk
30 Mar 2020 20:28 #162138
by Chipmunk
Hello BeagleBrainz
I have had a look at the operating system, first of all the machine has been partitioned so that it will run Windows XP and Linux EMC2, 2.4.6 using Ubuntu 10.04LTS
As for the Windows side of the unit all I could dig up is the following, Windows XP Version 2002 Service Pack 3 , now it says Windows NT 32, The processor is a AMD Semprom 2200 1.5 GHZ., As for on board RAM I don't have an answer for that and the only reference to memory is 15.9 GB 3.3 used and 12.5 available .
- BeagleBrainz
- Visitor
30 Mar 2020 21:38 #162150
by BeagleBrainz
You will need at 32 bit install, I think wheezy may fit that bill.
All the Mint versions are 64 bit.
- Chipmunk
30 Mar 2020 21:42 #162152
by Chipmunk
Thank You BeagleBrainz for the prompt answer.. I will download Wheezy 32 bit along with the latest version of Linux CNC.
- Thank you received: 7488
30 Mar 2020 21:55 #162160
Replied by tommylight on topic Upgrading
You might not be able to get the latest version for now, so try later.
