- Thank you received: 126
Script for automated testing of computer latency.
- seuchato
6 years 2 months ago - 6 years 2 months ago #180216
by seuchato
Replied by seuchato on topic Script for automated testing of computer latency.
Hi all
I am currently updating the script a bit. My intentions are:
I got thursday off, so I could work on some more stuff if desired. So, let the ideas come.
greez chris
- some debugging in prettier / clearer outputs
- add code to list parports and maybe their current config values like address, io etc.
- add a hint what output to place to the results thread
- option to just get the hw data and skip latency test
- option to just do latency test with latency summary only
- skip the .lat file by default but leave an option to have it generated all the same
greez chris
Last edit: 6 years 2 months ago by seuchato. Reason: typos
- Thank you received: 7491
6 years 2 months ago #180228
Replied by tommylight on topic Script for automated testing of computer latency.
Just changing the base period question to "are you using a parallel port" should do.
It seems all users run the default test but most of them do not need the base period at all.
- seuchato
6 years 1 month ago #180415
by seuchato
Good idea, I will look into that.
- JKAVS
6 years 1 month ago #180436
by JKAVS
Replied by JKAVS on topic Script for automated testing of computer latency.
Will the script become usable on Debian Wheezy with the upcoming update? I'd like to test a new computer with bootable USB stick, and the current version for download is based on Wheezy.
- seuchato
6 years 1 month ago #180529
by seuchato
JKAVS
I migrated my two wheezy based machines to buster in a wink of an eye. I think everyone can do it nicely. Wheezy is outdated and not being maintained. An updated script would be +/- just for wheezy and that will +/- double the effort. I honestly think it is not worth it. Thus, I will not update it to run under wheezy, sorry.
greez
chris
greez
chris
- seuchato
6 years 1 month ago #183342
by seuchato
Hi all
Took - well, really - some time more than I thought it would ...
After using the latest 2.8.0 iso from here , and running my script, I faced some weird issues like glxgears not being (kind of) randomly resized, I saw myself in front of a heap of rework.
I added the following:
@tommylight:
Kindly replace the link in your first post with the script attached.
- detection of parports
- min/max logging of cpu temperatures (to give a hint on cpu throttling)
- better/more specific output regarding hard or software confguration/
- hopefully more stable behaviour
@tommylight:
Time to create page: 0.878 seconds
