- Thank you received: 126
Script for automated testing of computer latency.
- seuchato
6 years 3 weeks ago #185742
by seuchato
Replied by seuchato on topic Script for automated testing of computer latency.
BeagleBrainz
pointed out
, that for a latency test "one should stress the computer". This is also mentioned
here
. BeagleBrainz stated also, that this means io load, like disc access, like opying large files around etc.
So far, my script does none of this. It collects data of the hardware used and invokes a latency test with or without a base thread, depending users wish and/or if a parallel port is detected.
While I did exactly that (ripping a dvd to hd) for wheezy based install, I did not consider this being required to get "realistic" latency data when writing the script. It was my believe, that LnuxCNC, once loaded from disc, does by far most of its duties in Ram. It would read the gcode file yes, but these files almost never go into the GB range. The largest gcode file I have is ~22MB.
Prior to adding heavy disc io, I would like to understand the reasoning, as why this is really needed to get reliable, repeatable latency data for the - say - database in forum.linuxcnc.org/18-computer/39371-res...se-with-linuxcncthis thread.
So, kindly give me a hand, let me know why it is needed and - most important - what is needed.
Greez
chris
Greez
chris
- BeagleBrainz
- Visitor
6 years 3 weeks ago #185747
by BeagleBrainz
Replied by BeagleBrainz on topic Script for automated testing of computer latency.
Quoting from the docs. Emphasis by myself.
"The idea is to put the PC through its paces while the latency test checks to see what the worst case numbers are."
To me that would mean not to simulate a Linuxcnc session but to really put a heavy load on the computer. Similar to destructive testing of a product.
I guess you could create a file, write a certain amount of bytes from /dev/random, move the file around, delete the file, create another larger file, do the same, create a number of smaller files using the same method, move them around. Open a few random windows, move them around, close them.
- Thank you received: 7491
6 years 2 weeks ago #185764
Replied by tommylight on topic Script for automated testing of computer latency.
DD is very useful for that as it can be used to write zeros to HDD/SSD or read from them and write to nothing:
www.cyberciti.biz/faq/howto-linux-unix-t...nce-with-dd-command/
That is just one of many examples.
- seuchato
6 years 2 weeks ago #186227
by seuchato
@beaglebrainz: thanks for the hint. I will add io load.
@tommylight: thanks for the link, inspiring. Tomorrow I got off for the weekend. Apart from stripping weight off our FP2NC to hopefully get ot down to our workshop, I have nothing to do. Soooo, I'll probably be working on the script again.
Greez
chris
Greez
chris
The following user(s) said Thank You: tommylight, txtrone
- seuchato
6 years 2 weeks ago #186254
by seuchato
help needed:
Can someone that has no separate /home partition kindly post the result of:
Tia
chris
mount | grep -Ei "on /home"
Tia
chris
- BeagleBrainz
- Visitor
6 years 2 weeks ago #186256
by BeagleBrainz
rmurphy@thinkPad-t530:~$ mount | grep -Ei "/home"
Time to create page: 0.293 seconds
