- Thank you received: 7491
Script for automated testing of computer latency.
5 years 8 months ago #199288
Replied by tommylight on topic Script for automated testing of computer latency.
If you plan on using parallel port, set the base period to 50000 and test again, if not do not use a base period for testing.
Latency seems quite good and still useable for software stepping (parallel port), but i have no idea what the errors are and why.
- Cadmanxu
- Thank you received: 6
5 years 8 months ago #199316
by Cadmanxu
Replied by Cadmanxu on topic Script for automated testing of computer latency.
Thank you very much for your answer, I will make the change that you advise me. If I manage to solve the error or do the test with the script in any way, I will share the data as indicated in the post. Thanks for your help. Regards
5 years 8 months ago #199330
Even if the script does not finish there are still things to try and tune to get to use the PC.
Make a simple config for the machine and try to move it, or start a sim to get used to LinixCNC.
- Cadmanxu
5 years 8 months ago #199333
by Cadmanxu
Okay, I'll follow those steps, thanks for your advice !!!!I will try to do simulations because my machine is not ready yet.
- seuchato
- Thank you received: 126
5 years 8 months ago #199335
by seuchato
Replied by seuchato on topic Script for automated testing of computer latency.
Cadmanxu
I never saw any similar messages before. The script >should< have generated a *.hw file. Kindly post that.
In addition: Do you run things on "bare metal" or virtualized?
Greez
chris
Greez
chris
- Cadmanxu
5 years 8 months ago - 5 years 8 months ago #199338
by Cadmanxu
Thanks for responding and for your help. I have installed the graphical version of Linuxcnc, I don't know if that's what you mean ... - Do you run things in "bare metal" or virtualized? -
At first I thought it was a FireFox problem so I had changed the browser and I had redirected the script to chrome. After making the change to base period to 50000 that Tommy recommended, the script ran for 10 minutes giving me this data. Then I stopped with a Delay warning. The truth is that I don't know very well how to interpret this data and if my computer is optimal to start my configuration in it. Thanks in advance for any help and responses.
Last edit: 5 years 8 months ago by Cadmanxu.
Time to create page: 0.352 seconds
