- Thank you received: 6
Script for automated testing of computer latency.
- Cadmanxu
5 years 8 months ago - 5 years 8 months ago #199339
by Cadmanxu
Replied by Cadmanxu on topic Script for automated testing of computer latency.
Started google-chrome-stable with ' vimeo.com/150574260 '
Command for latency test is:
su linuxcnc -c "latency-histogram --bbinsize 1000 --base 50000 --sbinsize 1000 --nox 2>&1 | tee 1613676081.lat &"
Latency testing loop started jue feb 18 20:21:46 CET 2021,
should end after jue feb 18 22:21:46 CET 2021
Unexpected realtime delay on task 0 with period 50000
Swap useage: prerun: 0, running: 0
last latency data is as follows:.
504 secs base min: -29.700 uS max: 44.200 uS sdev: 1.900 uS
504 secs servo min: -33.600 uS max: 34.300 uS sdev: 2.100 uS
Last edit: 5 years 8 months ago by Cadmanxu.
- seuchato
- Thank you received: 126
5 years 8 months ago #199371
by seuchato
Replied by seuchato on topic Script for automated testing of computer latency.
Cadmanxu
kindly post the complete .hw file that the script generates. Like that we know what kind of machine you are using.
"virtualized or bare metal": if running in some virtual machine like virtualbox, xen etc. But I guess, that is not the case.
A hint: I had faulty RAM once. This caused Realtime Delay Message. Use memtest86 to check on that.
greez
chris
greez
chris
- Cadmanxu
5 years 8 months ago - 5 years 8 months ago #199391
by Cadmanxu
Thank you very much for your answer, I could not insert the .hw file, it did not let me insert it in the message I will try to do it again. I tell you that the previous file that I uploaded to this post called ipdlerror.txt was a file that I created by copying the error data that appeared in the script's terminal. The fault was mine because to explain my results I only had to attach the .hw files I understood. I apologize for the confusion that I may have caused by interpreting that this file came from your scripts to do this test. Thank you very much for your tool and for sharing it with new Linuxcnc users. Today I will follow the instructions you recommend in the forum and read the topics more thoroughly before writing. I made that mistake, could I try uploading the file in txt format if necessary?
- seuchato
5 years 8 months ago - 5 years 8 months ago #199439
by seuchato
Cadmanxu
on a terminal in your machine do:
where {fname} is the fileprefix of you {fname},hw file
Scroll up until you see the cat command again. Mark all the lines below, copy, then go to linuxcnc forum, add a reply, goto editor,
write " [ c o d e ] {Stuff to be pasted} [ c o d e ]"
where {Stuff to be pasted} is the {Stuff to be pasted} which is in your clipboard and omit the blanks in " [ c o d e ]" and "[ c o d e ]"
hit send and you are done
In the editor, you can also click on the "Attachments" button and add your file as an attachment.
It's hard to check the output you reported without knowing what hardware you use. To know what hardware gives what latency results, is the very purpose of my script
greez
chris
cat {fname}.hw
greez
chris
Last edit: 5 years 8 months ago by seuchato. Reason: clarification
- Cadmanxu
5 years 8 months ago - 5 years 8 months ago #199441
by Cadmanxu
I cannot execute those commands. I do not see that list doing
cat {fname} .hw
I'm sorry, I'm new to Linux too, the only thing I can do is copy the text as an answer, although it is not very long and I see that nobody does it like that it seems ...
cat {fname} .hw
Last edit: 5 years 8 months ago by Cadmanxu. Reason: error
- Cadmanxu
5 years 8 months ago #199447
by Cadmanxu
Time to create page: 1.027 seconds
