OptiPlex 980, i5 CPU 650 @ 3.20GHz
Result with Buster
LinuxCNC pc tests, version 20200619-b
General info:
Dell Inc., OptiPlex 980
Bios version A04, dated 09/11/2010
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 1652
CPU related data:
model name : Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
cpu cores : 2
stepping : 5
cache size : 4096 KB
RAM related data:
Maximum Capacity: 16 GB
Size: No Module Installed
GPU related data:
product: Core Processor Integrated Graphics Controller
configuration: driver=i915 latency=0
Os related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Desktop: KDE, Session:
Kernel related data:
Kernel 4.19.0-9-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0 processor.max_cstate=1 idle=poll isolcpus=1 "
Cpu idle driver: none
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech USB Receiver
Mice attached to USB:
Logitech, Inc. Cordless Mouse Receiver
Keyboards attached to USB:
MosArt Semiconductor Corp. Defender Office Keyboard (K7310) S Zodiak KM-9010
LinuxCNC related data:
LinuxCNC version is: 2.9.0~pre0.2237.g829ce3e65
Preparing for latency test:
Started glxgears No. 1
Started glxgears No. 2
Started glxgears No. 3
Started glxgears No. 4
Started glxgears No. 5
Started firefox with 'https://vimeo.com/150574260'
Latency testing loop started Fr Jun 19 17:59:28 CEST 2020,
should end after Fr Jun 19 19:59:28 CEST 2020
command for latency test is:
su xx -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee 1592582351.lat &"
Cleaning up
Closing browser firefox
termiated latency ...
.terminated glxgears ...
7206 secs servo min: -19.300 uS max: 17.800 uS sdev: 0.700 uS
7208 secs base min: -19.900 uS max: 17.600 uS sdev: 0.300 uS
Result with mint:
LinuxCNC pc tests, version 20200622-pre
General info:
Chipset: Intel Corporation 5 Series/3400 Series Chipset
The amount of swap currently used is 0
CPU related data:
cpu cores : 2
stepping : 5
RAM related data:
GPU related data:
Os related data:
PRETTY_NAME="Linux Mint 19.3"
Desktop: MATE, Session: mate
Kernel 5.4.0-0.bpo.4-rt-amd64
Cpu idle driver: intel_idle
Number of mice: 1
Creative Labs Defender Office Keyboard (K7310) S Zodiak KM-9010
LinuxCNC version is: 2.9.0~pre0.2245.g09397b8d3
should end after Mo Jun 22 11:14:46 CEST 2020
Latency testing loop started Mo Jun 22 09:14:46 CEST 2020,
su xx -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee 1592810064.lat &"
Unexpected realtime delay on task 0 with period 25000
Swap useage: prerun: 0, running: 0
last latency data is as follows:.
164 secs base min: -20.000 uS max: 22.000 uS sdev: 0.800 uS
164 secs servo min: -18.100 uS max: 16.900 uS sdev: 0.800 uS
PC seems suitable using Buster and kernel 4.19.0-9-rt-amd64. Not useable using mint and kernel 5.4.0-0.bpo.4-rt-amd64. Il try to use 4.19.0-9-rt-amd64 with mint and add the result here when done.
Greez
chris
Edit 19. Oct. 2020:
For BIOS settings, see this post
here
, at the bottom. Best BIOS version is A18.
