Results of latency test, list of computers tested for use with LinuxCNC
6 years 1 month ago #181685 by Himarc3D
seuchato wrote: Himarc3D
What were the latencies you got with mint?
tommylight already pointed out that debian is "a bit better" on latencies than mint. I observed the same when running the test on both mint (19.3 in my case) and debian buster (10.4 to 10.5) on the same machine.
Greez
chris
Sorry for late reply, im busy working!
The difference was minimal, i just let Debian because was the last in the tests.
I can test again this weekend and save the data, ill check the Mint with 2.8 release. Ill check next Thursday using p/2 mouse and keyboard too if make anu difference for my setup.
  • BeagleBrainz
  • New Member
  • New Member
6 years 1 month ago #181693 by BeagleBrainz
Chasing the last nano second of latency is not really worth it, especially with Mesa hardware.
The Mint 19.3 ISO with 2.8 should not be any different to the Mint 19.2 ISO with 2.8~pre as the both use the same 4.x series kernel (I found this to be the best). Exactly the same kernel actually from the same package. The Linuxcnc packages are compiled on a 19.2 box.
If there are latency issues and you want to use the Parallel Port there is a RTAI kernel that Andy is working on.
Reducing the amount of USB hardware can help with latency, one thing I do when machining is to turn off wifi.
6 years 1 month ago - 6 years 1 month ago #181738 by Himarc3D
BeagleBrainz wrote: Chasing the last nano second of latency is not really worth it, especially with Mesa hardware.
Thank you for advice but in my case i just will install it because i read somewhere from Tommy about things sometimes dont work like they are supposed to be using Debian, and many veterans here at forum use Mint, so ill follow you guys!
My minipc don’t have parallel port or expansion slot...actually i don’t recommended this minipc, get very hot and no way to use inside cabinet (passive here big cabinet, maybe i test positive pressure using welder vest like vortex ilask my friend to use his vortex for a while), if i swap dsub to hmi or vice versa the desktop become clean, after clean install of OS using any GUI i get clean desktop too, just right mouse click work and keyboard to invoke terminal and configure primary monitor.
The bios I disabled many things, include sound but the kernel loaded the module, I blacklisted sound, Bluetooth, wifi, everything I don’t need
Last edit: 6 years 1 month ago by Himarc3D.
6 years 1 month ago - 6 years 1 week ago #182603 by seuchato
Here is the result of a desktop version of a dell 980 withj a 4core i5 750 cpu, all cores enabled. This machine has four expansion slots, 1 pcix 1 pci and 2 pci express. One is used for an ATI GPU ([AMD/ATI] RV710 [Radeon HD 4550]). When running with base period 25`000, I got real time delays, thus this test is with a base period of 50`000.
Looking at the promising results of this 4 core i5, I will retest the 980 here (two core i5 cpu) and compare them.
LinuxCNC pc tests, version 20200905, started 15.09.2020 11:08:57 ******************************************************************************** General info: Dell Inc., OptiPlex 980 Bios version A18, dated 02/27/2018 Chipset: Intel Corporation 5 Series/3400 Series Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz cpu cores : 4 stepping : 5 cache size : 8192 KB ================================================================================ RAM related data: Maximum Capacity: 16 GB Size: 2048 MB Size: 2048 MB Size: 2048 MB Size: 2048 MB ================================================================================ GPU related data: product: RV710 [Radeon HD 4550] configuration: driver=radeon latency=0 ================================================================================ Parallel port related data: number of parallel ports is 1 parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP] ================================================================================ Os related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Desktop: KDE, Session: ================================================================================ Kernel related data: Kernel 4.19.0-10-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash idle=poll" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, good! Check if snd modules are loaded: No, good! ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : Logitech MX Anywhere 2 Mice attached to USB: Keyboards attached to USB: MosArt Semiconductor Corp. Defender Office Keyboard (K7310) S Zodiak KM-9010 LinuxCNC related data: LinuxCNC version is: 2.9.0~pre0.2800.g470fce12e ================================================================================ Preparing for latency test: Started glxgears No. 1 Started glxgears No. 2 Started glxgears No. 3 Started glxgears No. 4 Started glxgears No. 5 .......... Started firefox with 'https://vimeo.com/150574260' ================================================================================ Command for latency test is: su ck -c "latency-histogram --bbinsize 1000 --base 50000 --sbinsize 1000 --nox 2>&1 | tee -a 1600160922.lat &" Latency testing loop started Di Sep 15 11:09:11 CEST 2020, should end after Di Sep 15 13:09:11 CEST 2020 ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 53.0°C, TMax: 64.0°C, (high = +83.0°C, crit = +99.0°C) Core 1: Tmin: 54.0°C, TMax: 64.0°C, (high = +83.0°C, crit = +99.0°C) Core 2: Tmin: 55.0°C, TMax: 65.0°C, (high = +83.0°C, crit = +99.0°C) Core 3: Tmin: 54.0°C, TMax: 64.0°C, (high = +83.0°C, crit = +99.0°C) ================================================================================ last latency data is as follows:. 7204 secs base min: -18.400 uS max: 19.400 uS sdev: 0.900 uS 7204 secs servo min: -11.900 uS max: 14.200 uS sdev: 1.600 uS
Greez
chris
PS: I will probably later add here in this post the very bios settings used
Edit: 19. Oct. 2020: Bios Settings are as follows, I only write up what I changed from defaults:
  • General
    • Boot sequence: Excluded "USB Floppy Drive" and "Onboard Network Controller"
    • Drives
    • "Diskette Drive" disabled
    • "SATA Operation": "RAID Autodetect /AHCI"
    • "SMART Reporting": enabled
  • System Configuration
    • "Parallel Port": EPP
    • "Miscellaneous Devices": disbled "Audio", "Opütiplex ON Reader" and "WiFi NIC Slot"
  • Performance
    • "Hyper-Threding Technology": disabled
    • "Intel(R) Turbo Boost Technology": disabled
    • "Intel(R) SpeedStep(TM)": disabled
    • "C States Control": disabled
  • Virtualization Support
    • "Virtualization": disabled
    • "VT for Direct I/O": disabled
  • Power Managment
    • "Low Power Mode": disabled
    • "Suspend Mode": S3 (there is no option to disable it completely)
Last edit: 6 years 1 week ago by seuchato. Reason: Added BIOS Settings
6 years 1 month ago #182604 by seuchato
BeagleBrainz wrote: Chasing the last nano second of latency is not really worth it, ...
100% true
BeagleBrainz wrote: ... 4.x series kernel (I found this to be the best).
Same conclusion here: 4x kernels are the best for the time being-
Greez
chris
  • BeagleBrainz
  • New Member
  • New Member
6 years 1 month ago #182605 by BeagleBrainz
Have 2 kernels you might want to give a go. These are the ones used on the Mint ISOs. The header & libc-dev packages are in the same dirs as linux-image-xxx.
The -rt46 has efi=runtime embedded in the kernel image but should not affect non UEFI systems.
cnc.beaglebrainz.net/mintcnc/pool/2.8-rt...t44-lcnc-1_amd64.deb
cnc.beaglebrainz.net/mintcnc/pool/2.8-rt...t46-lcnc-1_amd64.deb
Time to create page: 0.131 seconds
