Results of latency test, list of computers tested for use with LinuxCNC
6 years 1 month ago #183661 by txtrone
BeagleBrainz wrote: Do you think much about updating the firmware on the computer in your car ? Unless of course your into performance mods.
What about the 20 odd billion home appliances in a home that have a mcu ?
What about a tread mill or exercise bike ?
LOL I never thought about updating my car's firmware until my wife got a Tesla Model 3, now I have to update it as soon as the app lets me know one is available.It drives me crazy that I cannot update some of the glitches in my Ford via OTA updates! Furthermore, I hate it when my appliances are capable of being updated, but the manufacturer never offers an update... even though some of them clearly have bugs. I guess too many years of using Windows has me wanting to update everything all the time, or else.
I see your point. I will turn off the notification in the taskbar, out of sight out of mind,
  • BeagleBrainz
  • New Member
  • New Member
6 years 1 month ago #183662 by BeagleBrainz
Re Tesla. That would drive me insane.
Although I wrote a program to read and write the computer of my M900 I never messed with it, it goes hard, stops hard thanks to Beringer dinner plate discs and 6 piston calipers and the Ohlins suspension is fantastic.
The Ford one is easy. Buy a Holden as we used to say Down Under.
I have a '99 model Echo sedan I bought 5 years ago for $3000 and apart from the usual wear and tear it's great.....shame my previous V6 4Runner wasn't as great.
Anways in the update manager if you right click on a package you can ignore that particular update or ignore all updates for that package. I think you may even be able to turn the update manager off completely and update when and if you feel like it via apt-get. Least with Linux you have control without the gates of hell swallowing you up.
6 years 1 month ago #183663 by txtrone
BeagleBrainz wrote: Re Tesla. That would drive me insane.
"I can't leave right now, my car is in the middle of an update."
Thanks again, you have been very helpful... this forum in general seems to take it easy on noobs like myself.
When my hardware arrives I am going to try running it with your Mint 19.3 ISO. I have been using Mint on my personal PC (all updates all the time of course) for about a year, so I know enough to be dangerous.
The following user(s) said Thank You: Clive S, BeagleBrainz
6 years 1 month ago - 6 years 1 month ago #183735 by seuchato
While Teslas might be interesting to discuss (off topic), I'll add some results to bring this thread back to topic :-)
Below you'll find the results of a Lenovo t500: not useable! This despite disabling everything suspicious to impair latency in bios.
@beaglebrainz: your kernels install and run just fine on debian buster, as you may note below.
LinuxCNC pc tests, version 20200922, started 25.09.2020 14:33:55 ******************************************************************************** General info: LENOVO, 2241BM7 Bios version 6FET92WW (3.22 ), dated 12/14/2011 Chipset: Intel Corporation Mobile 4 Series Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz cpu cores : 2 stepping : 10 cache size : 3072 KB ================================================================================ RAM related data: Maximum Memory Module Size: 4096 MB Maximum Total Memory Size: 8192 MB Maximum Capacity: 8 GB Maximum Memory Module Size: 4096 MB Maximum Total Memory Size: 8192 MB Installed Size: 2048 MB (Double-bank Connection) Enabled Size: 2048 MB (Double-bank Connection) Installed Size: 2048 MB (Double-bank Connection) Enabled Size: 2048 MB (Double-bank Connection) Size: 2048 MB Size: 2048 MB ================================================================================ GPU related data: product: Mobile 4 Series Chipset Integrated Graphics Controller product: Mobile 4 Series Chipset Integrated Graphics Controller configuration: driver=i915 latency=0 configuration: latency=0 ================================================================================ Parallel port related data: number of parallel ports is 0 ================================================================================ Os related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Windowmanager = Xfwm4 ================================================================================ Kernel related data: Kernel 4.19.106-rt46-lcnc GRUB_CMDLINE_LINUX_DEFAULT="quiet splash isolcpus=3" Cpu idle driver: acpi_idle Kernel modules data: Check if pcspkr is loaded: ================================================================================ No, which is good! Check if snd modules are loaded: Yes, may cause bigger latency. can probably be disabled in bios ================================================================================ Keyboard & Mouse related data: Number of mice: 3 Mouse 0 : Logitech USB Receiver Mouse 1 : SynPS/2 Synaptics TouchPad Mouse 2 : TPPS/2 IBM TrackPoint Mice attached to USB: Logitech, Inc. Cordless Mouse Receiver Keyboards attached to USB: ================================================================================ LinuxCNC related data: LinuxCNC version is: 2.8.0 ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID 25166086 ================================================================================ Command for latency test is: su ck -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601037234.lat &" Latency testing loop started Fr Sep 25 14:34:11 CEST 2020, should end after Fr Sep 25 16:34:11 CEST 2020 ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 61.0°C, Tmax: 69.0°C, (high = +105.0°C, crit = +105.0°C) Core 1: Tmin: 59.0°C, Tmax: 69.0°C, (high = +105.0°C, crit = +105.0°C) ================================================================================ last latency data is as follows:. 7202 secs servo min:-431.100 uS max: 428.800 uS sdev: 3.200 uS 7202 secs servo min:-431.100 uS max: 428.800 uS sdev: 3.200 uS
greez
chris
Last edit: 6 years 1 month ago by seuchato. Reason: typos
  • BeagleBrainz
  • New Member
  • New Member
6 years 1 month ago #183781 by BeagleBrainz
You colud try again but rather [cdoe]isolcpu=3[/code] try either 0 or 1
If you have SpeedStep enabled in the BIOS, try to disable that as well.
6 years 1 month ago - 6 years 1 month ago #183894 by txtrone
Same Lenovo laptop model E430, running Mint 20 this time.
LinuxCNC pc tests, version 20200922, started 24.09.2020 21:49:49 ******************************************************************************** General info: LENOVO, 3254CTO Bios version H0ET98WW (2.58 ), dated 08/18/2016 Chipset: Intel Corporation 7 Series/C216 Harddisk is rotational The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz cpu cores : 1 stepping : 9 cache size : 3072 KB ================================================================================ RAM related data: Maximum Capacity: 16 GB Size: No Module Installed Size: 4096 MB ================================================================================ GPU related data: product: 3rd Gen Core processor Graphics Controller configuration: driver=i915 latency=0 ================================================================================ Parallel port related data: number of parallel ports is 0 ================================================================================ Os related data: PRETTY_NAME="Linux Mint 20" Windowmanager = ================================================================================ Kernel related data: Kernel 4.9.0-13-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" Cpu idle driver: intel_idle ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, which is good! Check if snd modules are loaded: Yes, may cause bigger latency. can probably be disabled in bios ================================================================================ Keyboard & Mouse related data: Number of mice: 2 Mouse 0 : SynPS/2 Synaptics TouchPad Mouse 1 : TPPS/2 IBM TrackPoint Mice attached to USB: Keyboards attached to USB: ================================================================================ LinuxCNC related data: LinuxCNC version is: 2.8.0.41.g8f4f8aa68 ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID 62914737 ================================================================================ Command for latency test is: su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601002180.lat &" Latency testing loop started Thu 24 Sep 2020 09:50:04 PM CDT, should end after Thu 24 Sep 2020 11:50:04 PM CDT ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 58.0°C, Tmax: 80.0°C, (high = +87.0°C, crit = +105.0°C) ================================================================================ last latency data is as follows:. 7200 secs servo min:-223.200 uS max: 212.400 uS sdev: 12.100 uS 7201 secs servo min:-223.200 uS max: 212.400 uS sdev: 12.100 uS
Last edit: 6 years 1 month ago by txtrone.
Time to create page: 0.380 seconds
