LinuxCNC pc tests, version 20200922, started 26.09.2020 22:10:45
General info:
Bios version , dated Chipset: Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : ARMv7 Processor rev 3 (v7l)
RAM related data:
GPU related data:
Parallel port related data:
number of parallel ports is 0
Os related data:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
Windowmanager =
Kernel related data:
Kernel 4.19.71-rt24-v7l+
Cpu idle driver: ================================================================================
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios
Keyboard & Mouse related data:
Number of mice: 0
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID
Command for latency test is:
su pi -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601176201.lat &"
Latency testing loop started Sat 26 Sep 2020 10:11:03 PM CDT,
should end after Sun 27 Sep 2020 12:11:03 AM CDT
Swap useage: prerun: 0, running: 0
CPU core temperatures:
last latency data is as follows:.
7203 secs servo min:-126.900 uS max: 146.900 uS sdev: 2.600 uS
