- Thank you received: 106
BeagleBrainz wrote: For general use for running a machine no.
Unless you intend building Linuxcnc from source or using qt based screens. I'm can't comment on the Debian based ISOs but the Mint ones I put together will get you up & running without having to install anything apart from the deps for qt if needed if you wish to use one of the "eye candy" screens.
Yes the general rule is to disable as much power saving & speed step options as possible, this is mentioned ad nauseam on just about every thread discussing latency, tho this can cause a laptop to run a little hotter than normal.
BeagleBrainz wrote: I would guess that there are systems still running early versions of Linuxcnc on Ubuntu 10 that are performing just as well now as the day there were installed.
