Results of latency test, list of computers tested for use with LinuxCNC
6 years 1 month ago #180798 by seuchato
Hi all, Results for an IBM Thinkpad Z61p: not useable. Plus: the BIOS has been password locked. Can't change anything :-(
LinuxCNC pc tests, version 20200905, started 05.09.2020 12:31:59 ******************************************************************************** General info: LENOVO, 0674GEG Bios version 7FETA9WW (2.27 ), dated 08/26/2009 Chipset: Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz cpu cores : 2 stepping : 6 cache size : 4096 KB ================================================================================ RAM related data: Maximum Memory Module Size: 2048 MB Maximum Total Memory Size: 4096 MB Maximum Capacity: 2 GB Maximum Memory Module Size: 2048 MB Maximum Total Memory Size: 4096 MB Installed Size: 2048 MB (Double-bank Connection) Enabled Size: 2048 MB (Double-bank Connection) Installed Size: 2048 MB (Double-bank Connection) Enabled Size: 2048 MB (Double-bank Connection) Size: 2048 MB Size: 2048 MB ================================================================================ GPU related data: ================================================================================ Parallel port related data: number of parallel ports is 0 ================================================================================ Os related data: PRETTY_NAME="Linux Mint 19.3" Desktop: MATE, Session: mate ================================================================================ Kernel related data: Kernel 4.9.0-12-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0 processor.max_cstate=1 idle=poll isolcpus=1" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, good! Check if snd modules are loaded: Yes, may cause bigger latency. ================================================================================ Keyboard & Mouse related data: Number of mice: 2 Mouse 0 : Logitech USB Receiver Mouse 1 : TPPS/2 IBM TrackPoint Mice attached to USB: Logitech, Inc. Cordless Mouse Receiver Keyboards attached to USB: LinuxCNC related data: LinuxCNC version is: 2.9.0~pre0.2747.gb86438619 ================================================================================ Preparing for latency test: Started glxgears No. 1 Started glxgears No. 2 Started glxgears No. 3 Started glxgears No. 4 Started glxgears No. 5 .......... Started firefox with 'https://vimeo.com/150574260' ================================================================================ Command for latency test is: su ck -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1599301911.lat &" Latency testing loop started Sa Sep 5 12:32:17 CEST 2020, should end after Sa Sep 5 14:32:17 CEST 2020 Useless to proceed, read the relevant part in 1599301911.lat >>>Unexpected realtime delay on task 0 with period 1000000<<< ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 77.0°C, TMax: 88.0°C, (high = +100.0°C, crit = +100.0°C) Core 1: Tmin: 77.0°C, TMax: 88.0°C, (high = +100.0°C, crit = +100.0°C) ================================================================================ last latency data is as follows:. 128 secs servo min:-878.500 uS max: 878.800 uS sdev: 3.700 uS 129 secs servo min:-878.500 uS max: 878.800 uS sdev: 3.700 uS
The lapy will be used in my workshop for browsing and music playing. It will not drive any cnc!
greez
chris
6 years 1 month ago - 6 years 1 month ago #181151 by Himarc3D
Hi, guys.
Fanless Mini PCModel K4-I5-4200U from Aliexpress i received 4/9/2020, i tested Mint 19.2 and 20, Debian gave me better result.
LinuxCNC pc tests, version 20200624, started 07.09.2020 18:50:32 ******************************************************************************** General info: Intel, H81U Bios version 5.011, dated 07/31/2019 Chipset: Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz cpu cores : 2 stepping : 1 cache size : 3072 KB ================================================================================ RAM related data: Maximum Capacity: 16 GB Maximum Voltage: Unknown Maximum Voltage: Unknown Size: 8192 MB Size: No Module Installed ================================================================================ GPU related data: product: Haswell-ULT Integrated Graphics Controller configuration: driver=i915 latency=0 ================================================================================ Os related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Desktop: , Session: ================================================================================ Kernel related data: Kernel 4.19.0-10-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0 processor.max_cstate=1 idle=poll isolcpus=1" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, good! Yes, may cause bigger latency. Check if snd modules are loaded: No, good! Yes, may cause bigger latency. ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : SteelSeries Sensei Raw Gaming Mouse Mice attached to USB: Keyboards attached to USB: Dell Computer Corp. Model L100 Keyboard LinuxCNC related data: LinuxCNC version is: 2.9.0~pre0.2747.gb86438619 ================================================================================ Preparing for latency test: Started glxgears No. 1 Started glxgears No. 2 Started glxgears No. 3 Started glxgears No. 4 Started glxgears No. 5 .......... Started firefox with 'https://vimeo.com/150574260' ================================================================================ Command for latency test is: su gd100 -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee 1599472222.lat &" Latency testing loop started Mon 07 Sep 2020 06:50:46 PM JST, should end after Mon 07 Sep 2020 08:50:46 PM JST Swap useage: prerun: 0, running: 0 ================================================================================ last latency data is as follows:. 7204 secs servo min: -60.300 uS max: 68.400 uS sdev: 7.900 uS 7205 secs servo min: -60.300 uS max: 68.400 uS sdev: 7.900 uS
Last edit: 6 years 1 month ago by Himarc3D.
The following user(s) said Thank You: seuchato, tommylight
6 years 1 month ago - 6 years 1 month ago #181503 by seuchato
Himarc3D
What were the latencies you got with mint?
tommylight already pointed out that debian is "a bit better" on latencies than mint. I observed the same when running the test on both mint (19.3 in my case) and debian buster (10.4 to 10.5) on the same machine.
Greez
chris
Last edit: 6 years 1 month ago by seuchato. Reason: typos
6 years 1 month ago #181509 by tommylight
Also Mint 19.3 XFCE is a bit better than Mint 19.3 Mate.
On two older laptops i can not get usable latency for a Mesa ethernet board with Preempt-RT and Mate, but i can get very usable latency with XFCE and same kernel.
The following user(s) said Thank You: seuchato, CORBETT
6 years 1 month ago #181550 by CORBETT
tommylight wrote: I do have 3 of the ASUS A270Z PRO MB in use, but not for machines ! :) They are busy mining ethereum.
Tom...
I had to go check that out and was some interesting reading about Ethereum. I had never really read about how it worked until seeing your post and had to go see what it was about.
Robert
6 years 1 month ago #181577 by tommylight
Feel free to start a topic about crypto in the "off topic" section so we can have a go at it, it is very good stuff but humans are humans so on one side they left it unused and on the other side they are doing everything to make it even more useless due to lack of ideas.
Time to create page: 0.253 seconds
