LinuxCNC pc tests, version 20200922, started 27.09.2020 12:06:05
General info:
LENOVO, 3254CTO
Bios version H0ET98WW (2.58 ), dated 08/18/2016
Chipset: Intel Corporation 7 Series/C216
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
cpu cores : 1
stepping : 9
cache size : 3072 KB
RAM related data:
Maximum Capacity: 16 GB
Size: No Module Installed
GPU related data:
product: 3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Windowmanager =
Kernel related data:
Kernel 4.19.0-10-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: Yes, may cause bigger latency.
can be elimintaed using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios
Keyboard & Mouse related data:
Number of mice: 2
Mouse 0 : SynPS/2 Synaptics TouchPad
Mouse 1 : TPPS/2 IBM TrackPoint
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 46137347
Command for latency test is:
su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601226348.lat &"
Latency testing loop started Sun 27 Sep 2020 12:06:19 PM CDT,
should end after Sun 27 Sep 2020 02:06:19 PM CDT
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 55.0°C, Tmax: 68.0°C, (high = +87.0°C, crit = +105.0°C)
last latency data is as follows:.
7203 secs servo min:-173.400 uS max: 167.900 uS sdev: 7.700 uS
7204 secs servo min:-173.400 uS max: 167.900 uS sdev: 7.700 uS
