Results of latency test, list of computers tested for use with LinuxCNC
6 years 4 months ago #172801 by seuchato
If, I would add a fan. The board has but one pci slot available. So it would be either pci or through an additional Nic eth. hang on to next post :-)
6 years 4 months ago - 6 years 4 months ago #172802 by seuchato
This a test for a Fujitsu esprimo 920. There are no expansion slots that would allow for an LPT to be added. So there is only a serve thread. The machine has a ton of bios options available to play. For this run I just switched off everything that seemed suspicious to impair latency. The system felt really responsive, the most responsive I've tested so far.
LinuxCNC pc tests, version 20200624, started 26.06.2020 13:15:22 ******************************************************************************** General info: FUJITSU, ESPRIMO Q920 Bios version V4.6.5.4 R1.37.0 for D3233-A1x, dated 08/06/2015 Chipset: Intel Corporation 8 Series Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM) i7-4765T CPU @ 2.00GHz cpu cores : 4 stepping : 3 cache size : 8192 KB ================================================================================ RAM related data: Maximum Capacity: 16 GB Size: 8192 MB Size: 8192 MB ================================================================================ GPU related data: product: Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller configuration: driver=i915 latency=0 ================================================================================ Os related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Desktop: KDE, Session: ================================================================================ Kernel related data: Kernel 4.9.0-12-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=0 processor.max_cstate=1 idle=poll" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, good! Yes, may cause bigger latency. Check if snd modules are loaded: No, good! Yes, may cause bigger latency. ================================================================================ Keyboard & Mouse related data: Number of mice: 2 Mouse 0 : USB-compliant keyboard Mouse 1 : Logitech USB Receiver Mice attached to USB: Logitech, Inc. Cordless Mouse Receiver Keyboards attached to USB: MosArt Semiconductor Corp. Defender Office Keyboard (K7310) S Zodiak KM-9010 LinuxCNC related data: LinuxCNC version is: 2.9.0~pre0.2258.gc90c1926d ================================================================================ Preparing for latency test: Started glxgears No. 1 Started glxgears No. 2 Started glxgears No. 3 Started glxgears No. 4 Started glxgears No. 5 .......... Started firefox with 'https://vimeo.com/150574260' ================================================================================ Command for latency test is: su ck -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee 1593170098.lat &" Latency testing loop started Fr Jun 26 13:15:35 CEST 2020, should end after Fr Jun 26 15:15:35 CEST 2020 Swap useage: prerun: 0, running: 0 ================================================================================ last latency data is as follows:. 7201 secs servo min: -34.700 uS max: 37.300 uS sdev: 2.800 uS 7202 secs servo min: -34.700 uS max: 37.300 uS sdev: 2.800 uS
My (preliminary) conclusion:
  • If possible: get this pc! I'll be surely lurking around.
  • Greez
    chris
    Edit: Dunno, but I'll try the hp 8300 with more ram too, so stand by
    Last edit: 6 years 4 months ago by seuchato.
    6 years 2 months ago - 6 years 2 months ago #179589 by tommylight
    HP 8300 Ultra Slim :
    LinuxCNC pc tests, version 20200624, started 26.08.2020 22:55:25 ******************************************************************************** General info: Hewlett-Packard, HP Compaq Elite 8300 USDT Bios version K01 v02.05, dated 05/07/2012 Chipset: Intel Corporation 7 Series/C216 Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name : Intel(R) Core(TM) i5-3470S CPU @ 2.90GHz cpu cores : 4 stepping : 9 cache size : 6144 KB ================================================================================ RAM related data: Maximum Capacity: 16 GB Size: 4096 MB Size: 4096 MB ================================================================================ GPU related data: product: Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller configuration: driver=i915 latency=0 ================================================================================ Os related data: PRETTY_NAME="Linux Mint 20" Desktop: , Session: ================================================================================ Kernel related data: Kernel 4.9.0-13-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" Cpu idle driver: intel_idle ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, good! Yes, may cause bigger latency. Check if snd modules are loaded: snd_hda_codec_hdmi 49152 1 snd_hda_codec_realtek 90112 1 snd_hda_codec_generic 73728 1 snd_hda_codec_realtek snd_hda_intel 40960 2 snd_hda_codec 135168 4 snd_hda_intel,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek snd_hda_core 90112 5 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec_realtek snd_hwdep 16384 1 snd_hda_codec snd_pcm 114688 4 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_hda_codec_hdmi snd_seq_midi 16384 0 snd_seq_midi_event 16384 1 snd_seq_midi snd_rawmidi 32768 1 snd_seq_midi snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi snd_timer 32768 2 snd_seq,snd_pcm snd 81920 15 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_pcm soundcore 16384 1 snd Yes, may cause bigger latency. ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : PixArt USB Optical Mouse Mice attached to USB: Keyboards attached to USB: Cherry GmbH G83 (RS 6000) Keyboard LinuxCNC related data: LinuxCNC version is: 2.9.0~pre0.2662.g3039a67a6 ================================================================================ Preparing for latency test: Started glxgears No. 1 Started glxgears No. 2 Started glxgears No. 3 Started glxgears No. 4 Started glxgears No. 5 .......... Started firefox with 'https://vimeo.com/150574260' ================================================================================ Command for latency test is: su cnc -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee 1598475314.lat &" Latency testing loop started Wed 26 Aug 2020 10:55:40 PM CEST, should end after Wed 26 Aug 2020 11:07:40 PM CEST Swap useage: prerun: 0, running: 0 ================================================================================ last latency data is as follows:. 720 secs servo min: -93.100 uS max: 105.700 uS sdev: 9.600 uS 720 secs servo min: -93.100 uS max: 105.700 uS sdev: 9.600 uS
    The test was running for 20 minutes while i was watching other stuff on youtube at full HD video quality.
    Not shabby at all ! Thanks to PCW who mentioned this as a very nice LinuxCNC PC.
    Beware of the power brick, quad cores come with 180W power supply that is big and heavy ! :)
    Last edit: 6 years 2 months ago by tommylight. Reason: typo
    6 years 2 months ago #179595 by seuchato
    Just one little thing: There is a hp 830 Elitebook. I guess you do not want your 8300 USDT to be held for the Elitebook?
    greez
    chris
    6 years 2 months ago #179602 by aparecido
    1598479016.HW
    LinuxCNC pc tests, version 20200624, started 26.08.2020 18:56:58
    General info:
    Itautec S.A., Infoway
    Bios version 0110, dated 03/02/2009
    Chipset: Harddisk is rotational
    The amount of swap currently used is 16732
    CPU related data:
    model name : Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz
    cpu cores : 1
    stepping : 10
    cache size : 3072 KB
    RAM related data:
    Maximum Memory Module Size: 4096 MB
    Maximum Total Memory Size: 8192 MB
    Installed Size: 1024 MB (Single-bank Connection)
    Enabled Size: 1024 MB (Single-bank Connection)
    Installed Size: Not Installed
    Enabled Size: Not Installed
    Size: No Module Installed
    GPU related data:
    Os related data:
    PRETTY_NAME="Linux Mint 19.3"
    Desktop: , Session:
    Kernel 5.4.0-0.bpo.4-rt-amd64
    Number of mice: 1
    Mouse 0 : ImPS/2 Generic Wheel Mouse
    LinuxCNC version is: 2.8.0~pre3.31.gb7c7ab5aa
    Started firefox with ' vimeo.com/150574260 '
    su aparecido -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee 1598479016.lat &"
    Latency testing loop started qua ago 26 18:57:18 -03 2020,
    should end after qua ago 26 20:57:18 -03 2020
    Unexpected realtime delay on task 0 with period 25000
    Swap useage: prerun: 16732, running: 27432
    23 secs servo min: -39.800 uS max: 52.100 uS sdev: 4.400 uS
    25 secs base min: -24.900 uS max: 74.600 uS sdev: 2.600 uS
    1598479016.lat
    Note: Using POSIX realtime
    This Message will only display once per session.
    Run the Latency Test and resolve before continuing.
    4 secs base min: -24.800 uS max: 28.300 uS sdev: 2.500 uS
    4 secs servo min: -15.200 uS max: 18.700 uS sdev: 4.800 uS
    5 secs base min: -24.800 uS max: 33.500 uS sdev: 2.400 uS
    5 secs servo min: -17.300 uS max: 19.700 uS sdev: 4.000 uS
    7 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    7 secs servo min: -29.700 uS max: 24.600 uS sdev: 3.900 uS
    8 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    8 secs servo min: -29.700 uS max: 24.600 uS sdev: 3.600 uS
    9 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    9 secs servo min: -29.700 uS max: 24.600 uS sdev: 3.500 uS
    11 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    11 secs servo min: -39.800 uS max: 52.100 uS sdev: 3.400 uS
    13 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    13 secs servo min: -39.800 uS max: 52.100 uS sdev: 3.600 uS
    14 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    14 secs servo min: -39.800 uS max: 52.100 uS sdev: 3.700 uS
    16 secs base min: -24.800 uS max: 46.900 uS sdev: 2.600 uS
    16 secs servo min: -39.800 uS max: 52.100 uS sdev: 3.800 uS
    17 secs base min: -24.800 uS max: 46.900 uS sdev: 2.500 uS
    17 secs servo min: -39.800 uS max: 52.100 uS sdev: 3.700 uS
    19 secs base min: -24.900 uS max: 58.400 uS sdev: 2.500 uS
    19 secs servo min: -39.800 uS max: 52.100 uS sdev: 3.900 uS
    20 secs base min: -24.900 uS max: 58.400 uS sdev: 2.600 uS
    20 secs servo min: -39.800 uS max: 52.100 uS sdev: 4.200 uS
    22 secs base min: -24.900 uS max: 58.400 uS sdev: 2.600 uS
    22 secs servo min: -39.800 uS max: 52.100 uS sdev: 4.300 uS
    23 secs base min: -24.900 uS max: 74.600 uS sdev: 2.600 uS
    6 years 2 months ago #179679 by seuchato
    aparecido
    Your machine seems to work on swap: "Swap useage: prerun: 16732, running: 27432" Add ram! Add 2 ram bars of same size. I would not go under 4GiB.
    Greez
    chris
    The following user(s) said Thank You: aparecido
