Installing LinuxCNC On HP T610 Thin Client
  • ALittleOffTheRails
  • New Member
  • New Member
4 years 9 months ago - 4 years 9 months ago #230664 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Installing LinuxCNC On HP T610 Thin Client
Why the 250us servo thread ?
I honestly think that if you had the same OS kernel and desk top environment you’d be getting the same or at least similar results.
The choice of desktop environment can affect latency due to the differing resources each consumes.
Gnome is on the heavier side where as xfce is one of the lighter ones.
When I did my respin of Mint I went for the xfce version as a base rather Mate. I tried a few kernels and decide on 4.19.106  as that gave better results than the 5 series available at the time.
Sometimes, probably more so on the lighter machines, the latest distro and kernel isn’t the best option.
Last edit: 4 years 9 months ago by ALittleOffTheRails.
4 years 9 months ago #230667 by Joco
In the case of this machine i suspect your issue is kernel/distro related.  When i did my initial work i tried debian 10 and ended up on mint 19.3 for a very good reason.
i have not done any tests on Debian 11(bullseye).  I am not surprised it performs poorly. If you are serious about needing bullseye then you might need to look at custom kernel compiles.
4 years 9 months ago #230668 by davidimurray
Thanks all
The main reason I've gone with Bullseye is so I can run qtpyvcp with python 3.
Sound like time to give up on the t610
  • New Member
  • New Member
4 years 9 months ago #230684 by ALittleOffTheRails
I don't think that would have been the best of ideas considering the specs of the little machine. Might have been a little too heavy for it.
4 years 9 months ago #230736 by Joco
I wouldn't be too quick to dismiss the T610.  I have Arch linux running on it with similar latency to my Mint 19.3 tests.  And when it comes to "modern" or "latest and greatest" not much is going to beat Arch.
Cheers - J.
  • New Member
  • New Member
4 years 9 months ago #230741 by ALittleOffTheRails
I was more thinking of the use qtpyvcp. The figures so far look like it should be good for Axis.
I'd be interested in giving Buster a go as well, with a 4.19.xxx kernel.
I have one that I'm waiting for delivery of.
I also have a T5135 that I have win98 on that I use for my Needham programmer.
Arch isn't really for those that are going to throw their hands up in the air.
A couple of years ago I had Linuxcnc running with Linux From Scratch.....yeah I really had some time on my hands.
Time to create page: 0.071 seconds
