OS Buster - Network-Manager
- Thank you received: 2176
27 Jul 2021 15:52 #216058
Replied by Aciera on topic OS Buster - Network-Manager
if you right click on the downloaded .ISO file then choose "Open With" -> "Other Application" you should get a list of applications. Check that list for "Disk Image Writer".
- Thank you received: 7488
27 Jul 2021 17:52 #216060
Replied by tommylight on topic OS Buster - Network-Manager
- mjones@welfab.ca
- Thank you received: 6
27 Jul 2021 19:23 #216063
by mjones@welfab.ca
Replied by mjones@welfab.ca on topic OS Buster - Network-Manager
I finally managed to make a system disk for 2.8.2 buster but having trouble with it. first it freezes at the configer connection section, to avoid that i disconnected my ethernet cable that go to the router and did it again. it then gives you an option of setting network up manualy where you put in ip address and all that stuff, then it goes on. Later it wants to connect to a mirror but comes up with an error for connection. after trying several times i went ahead with install without a mirror so as it says i only get a basic install. likely why i didn't have a burning program last time. is there a way to get it to redo the mirror part after i configure the network connection and get internet working.
- mjones@welfab.ca
27 Jul 2021 19:29 #216064
by mjones@welfab.ca
ok forget that last post. I just checked and this basic install doesn't even show networks any where.. I need to find out how to install and have it configure my network that goes out to the internet, but it locks up at that point. My origina install
had this window as well, it stopped for a minute but then continued. this one i have given half an hour and doesn't move on.
27 Jul 2021 23:28 #216081
Try this
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Most probably you have internet issues so the ISO is getting corrupt, do an md5sum for the ISO, see if it matches.
Time to create page: 0.139 seconds
