Linux-Mint-Rtos-Stormhold-5.11.4.
- Grotius
- Thank you received: 2349
26 Mar 2021 11:57 - 26 Mar 2021 13:54 #203698
by Grotius
Linux-Mint-Rtos-Stormhold-5.11.4. was created by Grotius
Linux-Mint-5.11.4 rt Stormhold edition.
Pre-installed
- Linux mint 64 bit
- Linuxcnc
- Linuxcnc-dev
- Ethercat-master
- Linuxcnc-ethercat
Extra's
- Parport kernel drivers
Feature's
- Set's mac adress at boot time
- Start's ethercat bus at boot time
Spec's
64 bit, 3Gb
Installation
- When usb or dvd boot's, hit a key within 10 sec. Install OEM version.
download link to website
direct download link
Pre-installed
- Linux mint 64 bit
- Linuxcnc
- Linuxcnc-dev
- Ethercat-master
- Linuxcnc-ethercat
Extra's
Feature's
Spec's
64 bit, 3Gb
Installation
Last edit: 26 Mar 2021 13:54 by Grotius.
The following user(s) said Thank You: sivaraj, tommylight, 0x2102, Aciera
- sqmathlete
- Thank you received: 18
26 Mar 2021 13:50 #203712
by sqmathlete
Replied by sqmathlete on topic Linux-Mint-Rtos-Stormhold-5.11.4.
Nice work! Can't wait for my download to finish!
- sivaraj
- Thank you received: 25
27 Mar 2021 07:55 #203781
by sivaraj
Replied by sivaraj on topic Linux-Mint-Rtos-Stormhold-5.11.4.
Nice work and Thank you.
But I would suggest use a LTS kernel instead of running behind latest kernel
www.kernel.org/category/releases.html
wiki.linuxfoundation.org/realtime/preempt_rt_versions
i feel either 4.19 or 5.4 kernel are most appropriate for longtime
- Grotius
27 Mar 2021 11:14 - 27 Mar 2021 16:48 #203793
by Grotius
Replied by Grotius on topic Linux-Mint-Rtos-Stormhold-5.11.4.
@Sivaraj,
Our member Stormhold was having some install problems related to ethercat in a other topic, not for above release !!
He had given me his os download link, that pointed to a Gnipsel tutorial. I took the latest kernel and compiled it.
That's the reason above kernel is incuded.
I know the 4.19 kernel is very good. But when you go to the 5 series, in debian there are some library compatible issues with
linuxcnc. I have a workaround for this.
To my surprise the buildbot that i used with Mint works out of the box. If in the future the buildbot build's in the /opt/ dir, this would
be perfect.
If you want to have a 4.19 kernel or a 5.4 kernel. I can make a download release for this versions.
If you have any other suggestions, like preinstalled pyvcp packages. no problem.
My suggestion to the downloaders is : Collect your improvements, post them over here. Then in a few day's we can make a
next release.
For example. I can set the power-savings to off. Or other thing's that are annoying.
be perfect.
next release.
Last edit: 27 Mar 2021 16:48 by Grotius.
- theshade
- Thank you received: 5
14 May 2021 01:22 #208774
by theshade
Replied by theshade on topic Linux-Mint-Rtos-Stormhold-5.11.4.
Hello @Grotius
I just installed Linux Mint 19 StormHold Rtos i
On a minix J50c-4 which has an RTL8111 which I wanted to use for ethercat
and the included intel BT/wifi 3168NGM.
Wifi works fine with the 4.15 kernel but doesn't in the RT kernel and it seems I can't just insmod or modprob the iwlwifi (because I saw that it wasn't set in the kernel config) /boot/config-5.11.4 -> CONFIG IWLWIFI is not set
I can't find the kernel sources nor the driver modules to get wifi to work-
inxi -i returns Device-2 Intel Dual Band .......... driver. N/A
So do I need to rebuild the kernell and modules or is there a quicker way?
Sorry to ask seems to me like a noobish question.. (in general I compiled the (RT) kernel myself andeverything, but what should I do here when it's "precompiled"?)
Seems the wifi works with th 4.15.22
Thanks for your nice work btw
- Grotius
14 May 2021 03:43 #208778
by Grotius
Nice pc !
I was wondering, can you buy them without a windows install?
I think rebuilding the kernel is a good solution, but a time consuming task.
If you succeed ,you could upload the kernel, then i can pick it up and put it
in the mint iso.
Ok, thanks.
For myself, i really like the linux-pro edition. I work with this version for a while now.
Nice pc !
in the mint iso.
Ok, thanks.
- theshade
16 May 2021 16:42 - 16 May 2021 16:54 #209120
by theshade
Dear Grotius,
I am sorry but I don't really understand a few things about the kernel image which
was provided as part of the Linux-Mint-Rtos-Stormhold-5.11.4
I installed with grub and after I compiled new versions of the kernel I can now compare both the version that you provided and the one which I compiled
but using the latency-histogram of the Mar25 compilation doesn't seem to be RT to me.. or at least not the fully preemptible version.
xx@xx-cnc:~$ uname -a
Linux xx-cnc 5.11.4-rt11 #1 SMP Thu Mar 25 13:15:14 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
- latency-histogram screen shot 16May2021-152
compared to the RT11+ I did compile as fully preemptible:
Linux xx-cnc 5.11.4-rt11+ #2 SMP PREEMPT_RT Sat May 15 23:06:08 CEST 2021 x86_64 x86_64 x86_64 GNU/Linux
But that is not all, I have tried with and without wireless but all my versions of the kernel with RT+ which I did (not sure why I do get a + sign) seem to make the GUI super slow (think 1 refresh every second when I move a window with the mouse), barely usable.
But I do get much better histogram tests. (see attachement screenshot)
With your kernel the GUI is behaving fine...
So it seems I only do get RT performance in the latency-histogram when the GUI is super slow
I checked the internet and I don't see anyone complaining on RT on the J5005 I did get one error in the dmesg though:
Also I need to add the mac address for the ethercat still
My experiments compiling RT Preempt on the raspberry 4 were not having such a slowing down effect so I wonder what can be wrong and also why is the kernel from 5.11.4RT not really having RT performance? (what was your config?)
Warning: Spoiler!
[ 1.498978] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.499114] i915 0000:00:02.0: [drm] couldn't get memory information
[ 1.499704] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 1.500865] i915 0000:00:02.0: Direct firmware load for i915/glk_dmc_ver1_04.bin failed with error -2
[ 1.500870] i915 0000:00:02.0: [drm] Failed to load DMC firmware i915/glk_dmc_ver1_04.bin. Disabling runtime power management.
[ 1.500874] i915 0000:00:02.0: [drm] DMC firmware homepage: git.kernel.org/pub/scm/linux/kernel/git/...rmware.git/tree/i915
[ 2.601816] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP
Warning: Spoiler!
[ 10.011177] ec_master: loading out-of-tree module taints kernel.
[ 10.019571] EtherCAT: Master driver 1.5.2 1.5.2-144-gb870761
[ 10.019632] EtherCAT ERROR: MAC address may not be empty.
Last edit: 16 May 2021 16:54 by theshade. Reason: added second screenshot
- theshade
16 May 2021 20:04 #209160
by theshade
- Grotius
17 May 2021 11:44 #209215
by Grotius
You have made it work now? Wifi ok?
- theshade
17 May 2021 17:21 #209244
by theshade
Dear Grotius,
I will summarise what I observed
1. Kernel 5.11.4 RT which came with image
- not RT
- no wifi
- GUI fast
2. kernel 5.11.4 RT + which I compiled
- RT
- wifi
- GUI super slow
3. kernel 4.19.190 RT
- RT OK
- wifi OK
- GUI OK
- no ethercat because it is an old kernel and ethercat from the image wasn't built against it.
- not RT
- no wifi
- GUI fast
- RT
- wifi
- GUI super slow
- RT OK
- wifi OK
- GUI OK
Time to create page: 0.240 seconds
