- Thank you received: 54
Help with a port to the STM32 would be greatly appreciated. Mbed gives some head start but there is no MODDMA version for the STM32 so the whole DMA communication will need to be coded from scratch. Can be done as this is how I started with the Arduino Due.STM32's are also hard to find right now, but that won't last forever.
I'm looking at porting this to STM32 for the future. Feel free to beat me too it![]()
Hi tomp,Hello,
Is there a difference between the diagram for skrv1.3 spi cable and your cable foto?
The disgram on readthedocs show a wire from what is labeled "p1.31" ( pin 4 of EXP2)
but your foto shows that socket empty., and instead a wire is connected to 3.25. ( pin 6 of EXP2)
Do I correctly see p1.31 is empty in your foto?
I am not geting the expected results and want to try correctly.
I just tried with what i see in the foto and still get bad spi ffffffff hitting F1 estop repreatedly
I then moved the 'reset' wire to the p1.31 and got same
Then I tried external 12V ps for skrv1.3
using screw terminal '12/14' and GND, moved jumper from 5V to INT.
Result is same ( spi cable is from p1.35 on skr to reset gpio25 on rpi 3B+)
also tried with reset line from p3.25 to rpi gpio25, same ffffffff
it does not work as expected
but i DO need to resolve the diagram vs foto for later
the pin in question really is p1.31 and really is on pin2 of EXP2.
(not on pin 6 ). This is from the SKR V1.3 config.txt.
My skr v1.3 is no longer a candidate for Remora.
I have recieved an MKS v1.3 and will make an SPI cable for that.
thanks,
tomp
