5 years 4 months ago #212992 by scotta
Ok, so below are some good pictures of the SKRv1.3 SPI cabling.
5 years 4 months ago - 5 years 4 months ago #212993 by scotta
I've also tested powering the controller board independently via the USB port. With no issues with SPI connection. However, I would not recommend this and to ensure that you have a common ground between the RPi and the controller board.
Last edit: 5 years 4 months ago by scotta.
5 years 4 months ago #213056 by scotta
Hi tomp,
Just noticed in your photo that you have +5v power coming from the controller board and have the power plugged into the RPi to. Not sure if this would be causing your issue but not a good idea to tie the grounds and the positive rails of the two together.
Brown wire below:
The following user(s) said Thank You: tjtr33, Doogie
5 years 4 months ago #213077 by Doogie
As Scott pointed out, you really do not want to connect the 5V "rail" of 2 devices which each product 5V outputs. But if you are trying to use logic signal between 2 boards, those signals are referenced from Ground so normally you just connect the grounds of the 2 devices together and now the signal voltages above ground can be sensed by the other device(s).
And the reason for not connecting the 2 5V outputs is that one might generate 4.95V and the other might be generating 5.15V and now you have a difference in potential, probably reverse power flow, excess power drain/heat and maybe other errors with 2 different potentials.
5 years 4 months ago #213244 by tjtr33
Hello,
Sorry I missed these messages,
I had put the project away until i get another board.
I got the 'skr v1.3' from
http://www.eak-electronic.com/index.php?route=common/home
there's a tiny thai/englisg flag icon to choose language
but its no longer listed, so the info is useless,
These boards are rare-er than parallel ports.
I will re re re re do the spi wiring with ribbin cable
and skip the serial
( thats where i had 5v and gnd from rpi , well,  maybe try with gnd but not 5v)
And will also wait for a new MKS v1.3
( the SKR 1.4 turbo was another lie that eventually got marked out of stock, and refunded )
thanks again I will monitor more closely while waiting
1 Question: do you have a sampe ngc file of a 3d Print?
 I wonder if I need custom M1xx codes.
tomp
5 years 4 months ago #213273 by scotta
Hi tomp,
I had to order another board a couple of days ago as I stupidly put a driver in backwards.. The chip shortage may be making these harder to get. I placed the order, but no order confirmation. The CN sellers are normally pretty responsive.
I have a set of custom M-code available for 3d printing. They are on my GitHub repository.
github.com/scottalford75/LinuxCNC-3D-Printing
I can share a simple 3d print ngc file if you like.
BR
Scott
Time to create page: 0.535 seconds
