Ok, got some packages in the mail this week, so time to try some things out. If some assistance could be provided that would be helpful and appreciated, because this setup is new to me.
Trying to set up a small BLDC/encoder with driver for axis, using aarons config as reference. The encoder is 100ppr, 2 channels. Max Rpm is 3000-6000. Im getting a little confused reading through the 2 github threads, is 100ppr/2channels going to be too much?
github.com/scottalford75/Remora/issues/12
github.com/scottalford75/Remora/issues/13
The pinout
PWN - pwn, 0v is max rpm, 5v is 0rpm
RUN/BRAKE - i/o output
CW/CCW - i/o output
EN_A - encoder count
EN_B - encoder count
, so encoder config looks straight forward, but how do I do the control pins? Am I hooking up PWM to a servo pin and then RUN to x enable pin? How can I handle the cw/ccw output io?
