5 years 3 months ago #215009 by Bari
Should I put together a schematic, gerbers and a BOM to give out to the Chinese to clone using STM32? Then everyone can get cheap boards with docs. Worst case you'll just have to add the parts they leave out to save a few $$.
5 years 3 months ago #215010 by Bari
I'd like to know which chip they are using as fake STM32's.
5 years 3 months ago - 5 years 3 months ago #215027 by mhel
Hi, Just thinking how this could evolve. Having a core code base that can call in LPC176x and STM32 dependencies would ease future maintainability. Of course we'd need to move to a community development and support mode as well.
I think Mbed platform is the way to go, it's well supported.
I downloaded the IDE, if I could make a blinky and a serial working with it, I could probably get it going.
The board Aaroncnc posted is a very good candidate, If I have a 3d printer, I'd get one myself.
FYSETC S6 V2
Last edit: 5 years 3 months ago by mhel.
5 years 3 months ago #215031 by mhel
 does the config need to be loaded every time because you are using  dev boards?
Yes, I don't have an sdcard on my board. this is exactly what I have STM32F4
The advantage of the PRU is, if your board has the same chip but different layout
you could (most likely) still use the firmware.
If I didn't make my port programmable  it would have been way better for me.
That configuration by serial port literally gave me a headache :)
5 years 3 months ago #215100 by scotta
FYSETC S6 V2
I need to do some more research, but I think the STM32 boards that support Marlin firmware are utilising a bootloader to flash the bin file from the SD card, just like the LPC176x boards. We'd need to be able to configure Mbed Studio for the appropriate STM target and be able to output a bin file with the correct starting address for the bootloader to jump to. It should be possible, as it was one of the first steps I had to do for the LPC176x boards. It was more straight forward though as Smoothieware was originally based on the Mbed framework.
