Hi muvideoThank you Scott for your thorough reply, and many thanks also for this project.
- inversion: I still didnt update the firmware with the new content but tried to use 1 instead of "True" and indeed the inversion works correctly.
- Steprate: ok so the maximum theoretical steprate Is coeherent with my experience, that's ok since I understand that your main target is 3D printers, the ability to use your project with a mill also very interesting. I lowered the steps per mm in the drivers configuration and lowered the maximum speeds and now the system is behaving Better. I still have to tinker with linuxcnc settings as I still have some overshoot problems.
- Feature request: it would be nice to be able to access board sd card trough USB as a generic disk storage. That would simplify initial configuration testings, for example for headless setups like mine, since I'm using vnc and the sd is not very accessible. The file would be accessibile directly trough os.
There is an example on the documents for a home limit switch combo. scroll to the bottom.Zuo99 post=216678 userid=29932
Hi muvideo
I am also trying to use REMORA to control the milling machine, but there are still some problems. I don't know if it is convenient for you to publish and upload your ini and HAL files. At the same time, I want to know about some of your devices such as the connection of limit switches. thank you very much for your help. Zuo
