Hi, for the Fysetc Spider we'll need to create another firmware variant to account for the SD card being over SPI vs SDIO. It looks like they may share the SPI on the EXP port with the SD card. I've got a shared version working for the STM32F1 boards, so the same should work for this board. The schematic needs some more study to config though.What are my options for boards with no SD card slot, and for boards with the SD card slot hooked into spi ?
I just got 2 fysetc boards in the mail, and forgot to figure it out before hand, the S6 has no sd slot and the Spider looks like sd slot is connected to an spi channel,
bari, the ethernet board is a 407
I personally needed 45KHz using 4mm pith and 16x micro-stepping to get the speeds I needed.
explain, because I have not observed or read about microstepping having any relation on speed. but those who do want higher output frequencies, mxmaster made some kind of stepgen multiplier
github.com/kubroid/steps-frequency-multiplier
