- Thank you received: 167
I got ya, I won't be doing any work on that myself, I don't know anything useful about programming. Good to know what the actual holdup is, I can keep my eye out for changes in the future.so, as I understand remora, the iMXrt1062 is not supported by mbedOS, so its probably a non-starter. the imxrt-1050 is supported, and there were a few threads on teensy forum about support for 4.0, but thats about it. you could probably use the remora.comp with your own custom non mbedos firmware, but you could do that with other spi comps also. But the main thing going on as I understand it, is that the remora firmware is based on mbedos framework
