4 years 10 months ago #229223 by Cncninja
The stm32 it just to run the heat bed the Step Dir and Normal I/O is being done on the RPI.
4 years 10 months ago #229224 by Cncninja
PandaPi: use RPi to control 3D printer directly,except the temperature control which is just to maintain the temperature.
Klipper: uses a RPi to parse G-code,map out curves,set accelerations,and then send the motor command to the MCU via uart.
the obvious difference is that PandaPi control the motor directly.the gpio on the RPi speed being able to signal at 10+ Mhz as compared to 8/32bit MCU limit of about 10Khz/200khz for steps.that is one of my reason to explore this project. although the <100Khz speed is enough for our FDM printer recently but not the future.
Why is there a mcu?
RPi has not enough GPIO pin for handle all the motors,hotend,bed,endstop,LCD,auto bed level,run out sensor.
how do this assure the real time control?
about the real-time, here is the result that is almost perfect for real time control drivers. the output signal of the one raspberryPI's GPIO,and displayed by the oscilloscope.
4 years 10 months ago #229225 by Bari
I also see Step and Dir from the STM32 but who knows?. The docs are terrible and you'd have to dig into their source.
There are just many different ways to write firmware. Getting the most out of a micro requires you to know how the microcontroller works and designing accordingly.
4 years 10 months ago #229226 by Cncninja
4 years 10 months ago #229227 by Cncninja
Yep Agree, that's why I'm a bit lost why the speed difference on the same hardware.
4 years 10 months ago #229228 by Cncninja
Time to create page: 0.359 seconds
