- Hardware & Machines
- Computers and Hardware
- Remora - Rpi Software Stepping Using External Microcontroller via SPI
- drewnabobber
- Thank you received: 27
20 Nov 2022 00:12 #257131
by drewnabobber
Replied by drewnabobber on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
For an example of modifying Remora to work with a static config, the modified fork for the Flexi-HAL board is now public:
github.com/Expatria-Technologies/remora-flexi-hal
The following user(s) said Thank You: tommylight, cakeslob
- cakeslob
- Thank you received: 280
21 Nov 2022 01:28 #257188
by cakeslob
Replied by cakeslob on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hey Drew, thats some pretty good stuff you got there.
Looking through some of the stuff, the config stuff looks pretty good. its easy to understand so I like it. I bet we can merge it into regular remora by making it a target compile flag based thing or maybe a target specific fallback for no sd config.
I am curious about the other stuff though and specifically 446. I have issues with my 446 boards, so I would find your insights valuable. The other changes, I see the enable thing in stepgen, and something with the pru, but if you could elaborate for me....
I did a thing to compare the 2
github.com/cakeslob/Remora/compare/devel...lob:Remora:flexi-hal
- 4170-thomasnobi
23 Nov 2022 10:50 #257447
by 4170-thomasnobi
Replied by 4170-thomasnobi on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hello all,
I am running LinuxCnc with an Octopus Pro board and Remora firmware. All works fine except that the servos motors make cracking noises when reversing the load. With the oscilloscope I see that when the DIR Pin changes also the first Puls starts (~120ns). I assume that the problem comes from there. But I can not find a setting where I can set the values for Dirhold and Dirsetup.
I have tried:
setp remora.joint.0.dirhold 10000
setp remora.joint.0.dirsetup 10000
Remark from the Servo Manuel:
(1) t1: ENA must be ahead of DIR by at least 5μ s. Usually, ENA+ and ENA- are NC
(not connected).
(2) t2: DIR must be ahead of PUL active edge by 6μ s to ensure correct direction;
(3) t3: Pulse width not less than 2.5μ s;
(4) t4: Low level width not less than 2.5μ s.
My hardware:
Rasperry Pi4 4Gb with the RT image.
Octopus Pro Board via SPI
JMC IHS57 Servos
Software:
LinuxCNC 2.8.3
Remora 1.1.0
I hope someone can help me.
Thanks and greetings
Thomas
I have tried:
(not connected).
My hardware:
JMC IHS57 Servos
Software:
LinuxCNC 2.8.3
Remora 1.1.0
Thomas
- scotta
- Thank you received: 489
27 Nov 2022 21:16 #257764
by scotta
Replied by scotta on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Currently there is no setup and hold settings available in Remora as it has not been an issue.
Looking at your servos, they are expecting a differential pair driving them. Not sure if this is the issue but maybe worth a try to use some adaptors like
www.makerstore.com.au/product/elec-drv-adapter/
BR
Scott
BR
Scott
The following user(s) said Thank You: 4170-thomasnobi
- cakeslob
07 Dec 2022 00:37 #258772
by cakeslob
Ive seen this in sim, but running into this issue on one of my physical machines, so I would like address this. Based on this post, scott, is this the change you would like to make to address the issue? I made a separate repo with this change, if this is what you were thinking I can push it through.
github.com/cakeslob/Remora/tree/dev_disabling-interrupts
The long standing issue crops up enough to make the lathe unusable. You can move the system on either axis and when it stops or nears stopping, it (sometimes) suddenly jumps into motion (step change) and starts slowing down. This can be seen below. The position feedback value changes and the system compensates.
-Rafal
I'm curious as to whether we've got a similar issue that was a bug in the Remora-NVEM version where the data move was being interrupted and corrupted by the threads. It was fixed by disabling interrupts before moving the data.
Doing the same in RemoraComms.cpp at lines 165 may do the trick.// ensure an atomic access to the rxBuffer // disable thread interrupts __disable_irq(); // then move the data for (int i = 0; i < BUFFER_SIZE; i++) { rxData.rxBuffer[i] = rxBuffer.rxBuffer[i]; } // re-enable thread interrupts __enable_irq();
- scotta
07 Dec 2022 00:50 #258774
by scotta
Hi, yes that would be the fix. Thanks
- cakeslob
07 Dec 2022 01:04 #258777
by cakeslob
Recently things with mbed have spurred a community fork of mbed called mbed-ce, with our friend jojo as an active developer. I think the goal being actual updates to hardware bugs.
github.com/mbed-ce/mbed-os
Basically they are working imxrt1062 aka teensy4 support for mbed, and need people to help test. Since Im stupid as shit, I will be fumbling my way through, but if anyone else is interested, here are a few links to the stuff
github.com/mbed-ce/mbed-os/pull/113
github.com/mbed-ce/mbed-os/discussions/109
The following user(s) said Thank You: scotta
- mburwell
18 Dec 2022 22:31 #259859
by mburwell
Replied by mburwell on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hello,
Haven't ever used a forum like this before sorry if I am doing this incorrectly.
I am trying to get remora working on an SKR 1.3 board with an RPI4. I'm sure this is something stupid simple, everything appears to be working as far as SPI between the RPI4 and the SKR 1.3 but when I take it out of estop in linuxcnc and click to power it on in linuxcnc everything seems good. As soon as I try to move any axis I get a joint follower error.
I am using the remora xyz config for linuxcnc and it is as-is from when i downloaded it. I am clueless as to where to start looking for the issue.
Any help would be great, thank you.
- virencq
- Thank you received: 5
19 Dec 2022 04:34 #259874
by virencq
Replied by virencq on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hello,
I am eager to know what is the fastest stepgen rate STM32F4 board support.
- scotta
21 Dec 2022 21:59 #260041
by scotta
Is the SKRv13 config,txt loaded onto the SD card? You would get the following error if there is no stepgen loaded.Hello,
Time to create page: 0.222 seconds
